Ricoh Ricoh SP213SFW Mono Laser Multifunction Printer
Quicklinx: CDD2WS00 Mfr#: 904237
The SP 213SFw combines high productivity with ease of use in a compact package. A fast print speed, colour scanning and high speed G3 faxing enhance small/home office performance. This MFP is also very easy to use via the user-friendly 4-line LCD panel and everything can be done from the front of the device. ID Card Copy is another time-saving feature allowing you to copy both sides of an ID card onto one side of paper. You can also send print data directly from a smart device such as a smartphone or tablet. To top it off, paperless fax reception, manual double-sided printing and a high-yield, all-in-one print cartridge reduce your overall costs.
  • Fast: 22 pages per minute
  • High resolution: 1,200 x 600 dpi
  • Effortless printing with Ricoh’s Smart Device Print & Scan
  • Mobile app
  • ID Card Copy & colour scanning
  • Manual double-sided printing & PCL support
  • Wireless 4-in-1 MFP
  • B&W printing and copying, colour scanning, G3 fax
  • WiFi and USB 2.0 interfaces
  • Fast 27 second warm-up
  • First print delivered in 10 seconds
  • Scan in high-resolution colour
Ricoh - B/W - laser
Printer Type
- laser - B/W
Printer Type
- laser - monochrome
Printer
Wired
Internal
