Based on expertise in delivering in-house iSCSI & RAID stack, the TrioNAS LX U300 consolidates NAS and SAN offers multiple enterprise-level features with a competitive price to meet enterprise IT budget and specific needs.
TrioNAS LX U300 series deliver outstanding integration of Windows AD & LDAP for IT administrators to easily manage up to 75536 accounts. The support of Windows ACL simplifies privileges setting and provides access control, helping enterprises to manage IT infrastructures with minimum effort.
The UnifiedAUTH leverages domain authentication (AD, LDAP) to make users seamless access all data services.
With Access Auditing, IT administrators can easily track user and file activities through traceable records to ensure all the files be properly used or modified.
- Qsan TrioNAS LX U300-C424 - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 4U
- Installed Devices / Modules Qty
- 0 (installed) / 24 (max)
- 44.6 cm x 54.97 cm x 17.6 cm
- 34 kg ()
- Processor
- 1 x Intel Core i3 4330
- Storage Controller
- RAID SATA 6Gb/s / SAS 6Gb/s RAID RAID 0, 1, 5, 6, 10, 50, 60
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- RAM
- 16 GB
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- System Requirements
- Microsoft Windows XP, SunSoft Solaris 10, Microsoft Windows 7, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Microsoft Windows 2003 R2, Red Hat Enterprise Linux 5, Microsoft Windows Server 2008, Red Hat Enterprise Linux 6, SunSoft Solaris 11, Microsoft Windows Server 2012 R2
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Total Storage Capacity
- 0 GB
- 44.6 cm
- 54.97 cm
- 17.6 cm
- 34 kg ()
Processor / Memory
- Processors Installed
- RAM
- 16 GB (installed) / 32 GB (supported)
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s / SAS 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
- Data Link Protocol
- NTP, iSCSI, FTP, DHCP
- Remote Management Protocol
- SNMP, HTTP, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), WINS, File Level Security (ACLs), DHCP, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- DHCP support, trunking, LDAP support, VLAN support, wake on LAN (WOL), Syslog support, IPv6 support, Access Control List (ACL) support, Jumbo Frames support, teaming support, LACP support, e-mail notification, tagged VLAN
- Encryption Algorithm
- SSL, TLS
- Expansion Bays
- 24 (total) / 24 (free) x hot-swap
- 7 x Ethernet 1000Base-T - RJ-45
- Wake on LAN, built-in 3 cooling fans
- BSMI, FCC, RoHS
- Power Device
- Internal power supply
- Installed Qty
- 2
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- Power Provided
- 550 Watt
- 80 PLUS Certification
- 80 PLUS Gold
- Power Factor Correction
- Software Included
- McAfee AntiVirus
- OS Required
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
