TrioNAS U221 features enterprise-class DeDup eliminating duplicate copies of redundant data so as to save storage capacity significantly, and thereby SMBs can optimize storage space utilization and save costs greatly. Plus compression feature to encode information using fewer bits than original representation, storage capacity can be saved up to 90%.
TrioNAS U221 is equipped with 80 PLUS Platinum power supplies to enhance energy efficiency for power savings, peak reduction and improved power quality. In addition, TrioNAS features thin provisioning to allocate disk storage space in a flexible manner based on the minimum space required. With all the green designs, TrioNAS U221 helps organizations to save resources and money.
TrioNAS U221 is designed to addresses the explosion of unstructured data and files, where reads/writes are random, by treating random writes as sequential blocks. To provide better file data sharing, the ZFS-based storage system supports SMB v2.0, NFS v3/v4, AFP v3.3, FTP and SFTP, WebDAV, and iSCSI CHAP. In addition, TrioNAS U221 offers very easy-to-use management tools including QCentral, SNMP trap, performance states, and start-up wizard and so on. All these functions allow SMBs and work groups to manage TrioNAS U221 at minimum efforts and greatly enhance the efficiency in the working environment.
TrioNAS U221 adopts Intel Xeon E3 CPU to provide high availability and performance. At the same price, TrioNASU 221 provide more superb enterprise-level features; providing the same feature, TrioNASU 221 offers the best values to customers.
Integration NAS and iSCSI SAN, TrioNAS U221 unified architecture help customers to solve many data management problems with a single system, making complex and fast growing storage needs much more manageable and affordable.
DeDeup
TrioNAS U221 features enterprise-class DeDup eliminating duplicate copies of redundant data so as to save storage capacity significantly, and thereby SMBs can optimize storage space utilization and save costs greatly. Qsan DeDup technology provides real-time block-level redundancy removing function that is more efficient than file level one. The storage capacity savings with DeDup differ per data type. In general, DeDup can grant TrioNAS U221 space savings of up to 90% in backup and virtual machine, 70% in database baclup and 40% for email archive. -
ZFS file system
To provide better data integrity, TrioNAS U221 adopts ZFS file system that employs copy-on-write transactional semantics to validate data stored under its protection to avoid data inconsistencies. The self-healing architecture enables the system to detect silent data corruption and correct error on the fly. In addition, users no longer need to predetermine the size of a file system since it grow automatically within the disk space allocated to the pool to save storage capacity. If the storage pool becomes overcrowded, user can even grow it on a live TrioNAS U221 system. -
80 PLUS Platinum
TrioNAS U221 is equipped with 80 PLUS Platinum power supplies to enhance energy efficiency for power savings, peak reduction and improved power quality. The systems can automatically detect the fan speed, temperature as well as current/voltage inside the PSU to provide optimized settings and status alerts. Besides, the strain relief bushing can securely anchor and protect cables from push/pull and twist forces. -
SSD caching
SSD caching allows users to assign SSD as the system's read/write cache to fully utilize the benefits of SSD for business-critical applications that require quick read/write speed and random I/O. -
Thin provisioning
TrioNAS U221 delivers thin provisioning to provide more physical resources than actually available capacity so that organizations can avoid allocated but unused storage and be able to purchase only the disk capacity they actually need. Therefore, thin provisioning feature can significantly raise storage utilization and help enterprises to save cost. -
Compression
Data compression can also help users to better utilize the resources. With data compression, the size of data stored in TrioNAS can be greatly reduced to save storage capacity. -
Advanced data protection
To keep data safe, TrioNAS offers numerous advanced data protection features including snapshot, volume clone, file system clone, remote replication as well as McAfee antivirus protection. -
Multiple protocol supports
TrioNAS U221 supports SMB v2.0 and NFS v3/v4 for unicode files. It also supports AFP v3.3, FTP, SFTP, WebDAV and iSCSI CHAP that is always an integration headache on Linux system. -
Easy to manage
TrioNAS U221 can be centrally managed by QCentral the java-based cross-platform management interface. In addition, TrioNAS U221 also features online firmware upgrade, event notification via email and SNMP, performance states, system monitoring, MAID and S.M.A.R.T. supports, start-up wizard, wake-on-LAN and web UI. -
UnifiedAUTH
The UnifiedAUTH technology is that any OS client (Windows, Linux, Mac, FTP, and WebDAV) and iSCSI CHAP can log onto the TrioNAS LX device through Microsoft Active Directory with a single log-in. With UnifiedAUTH, IT administrators can just manage employees' accounts by Windows AD or LDAP, while end-users can easily use their Windows AD/LDAP ID and password to login via clients of any popular OS.
- Qsan TrioNAS U221 - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet / 10 Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 2U
- Installed Devices / Modules Qty
- 0 (installed) / 12 (max)
- 44.2 cm x 71.12 cm x 8.8 cm
- Processor
- 1 x Intel Xeon
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, 50, 60
- Networking
- Network adapter 10Mb LAN, 100Mb LAN, GigE, 10 GigE
- RAM
- 32 GB
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- System Requirements
- SunSoft Solaris, Apple MacOS, Red Hat Linux 5.0, Red Hat Linux 6.0 or later, Microsoft Windows
- 3-year warranty
- NAS server
- Host Connectivity
- Enclosure Type
- Total Storage Capacity
- 0 GB
- 44.2 cm
- 71.12 cm
- 8.8 cm
Processor / Memory
- Processors Installed
- 1 x Intel Xeon
- Max Supported Qty
- 1
- RAM
- 32 GB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
- Network adapter
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, GigE, 10 GigE
- NTP, iSCSI, FTP, DHCP
- Remote Management Protocol
- SNMP, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), DHCP, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
- DHCP support, trunking, LDAP support, VLAN support, wake on LAN (WOL), antivirus analysis, Jumbo Frames support
- Encryption Algorithm
- SSL, TLS
- IEEE 802.3ad (LACP)
- Expansion Bays
- 12 (total) / 12 (free) x hot-swap
- 2 x Ethernet 1000Base-T - RJ-45 , 2 x Ethernet 10Gb
- UL, BSMI, cUL, CB, FCC, RoHS
- Power Device
- Internal power supply
- Installed Qty
- 2
- Power Redundancy
- Voltage Required
- Power Provided
- 549 Watt
- OS Required
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
