Integration NAS and iSCSI SAN, TrioNAS U210 unified architecture helps customers to solve many data management problems with a single system, making complex and fast growing storage needs much more manageable and affordable.
ZFS file system
To provide better data integrity, TrioNAS U210 adopts ZFS file system that employs copy-on-write transactional semantics to validate data stored under its protection to avoid data inconsistencies. The self-healing architecture enables the system to detect silent data corruption and correct error on the fly. -
80 Plus Platinum
TrioNAS U210 is equipped with 80 Plus Platinum power supplies to enhance energy efficiency for power savings, peak reduction and improved power quality. The systems can automatically detect the fan speed, temperature as well as current/voltage inside the PSU to provide optimized settings and status alerts. Besides, the strain relief bushing can securely anchor and protect cables from push/pull and twist forces. -
SSD caching
SSD caching allows users to assign SSD as the system's read/write cache to fully utilize the benefits of SSD for business-critical applications that require quick read/write speed and random I/O. -
Thin provisioning
TrioNAS U210 delivers thin provisioning to provide more physical resources than actually available capacity so that organizations can avoid allocated but unused storage and be able to purchase only the disk capacity they actually need. Therefore, thin provisioning feature can significantly raise storage utilization and help enterprises to save cost. -
Compression
Data compression can also help users to better utilize the resources. With data compression, the size of data stored in TrioNAS can be greatly reduced to save storage capacity. -
Advanced data protection
To keep data safe, TrioNAS offers numerous advanced data protection features including snapshot, volume clone, file system clone, remote replication. -
Easy to manage
TrioNAS U210 can be centrally managed by QCentral the java-based cross-platform management interface. In addition, TrioNAS U210 also features online firmware upgrade, event notification via email and SNMP, performance states, system monitoring, MAID and S.M.A.R.T. supports, start-up wizard, wake-on-LAN and web UI. -
UnifiedAUTH
The UnifiedAUTH technology is that any OS client and iSCSI CHAP can log onto the TrioNAS LX device through Microsoft Active Directory with a single log-in. With UnifiedAUTH, IT administrators can just manage employees' accounts by Windows AD or LDAP, while end-users can easily use their Windows AD/LDAP ID and password to login via clients of any popular OS.
- Qsan TrioNAS U210 - NAS server - 24 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 2U
- Total Storage Capacity
- 24 TB
- Installed Devices / Modules Qty
- 12 (max)
- 44.2 cm x 71.12 cm x 8.8 cm
- Processor
- 1 x Intel Core i3
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, 50, 60
- Networking
- Network adapter 10Mb LAN, 100Mb LAN, GigE
- RAM
- 16 GB
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- System Requirements
- SunSoft Solaris, Apple MacOS X, Red Hat Linux 5.x, Microsoft Windows, Red Hat Linux 6.x, Oracle Solaris
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- 24 TB
- 12 (max)
- 44.2 cm
- 71.12 cm
- 8.8 cm
Processor / Memory
- Processors Installed
- 1 x Intel Core i3
- RAM
- 16 GB (installed) / 32 GB (supported) - DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
Hard Drive
- HDD - hot-swap
- Network adapter
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, GigE
- NTP, iSCSI, FTP, DHCP
- Remote Management Protocol
- SNMP, HTTP, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), DHCP, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
- Trunking, VLAN support, wake on LAN (WOL), firmware upgradable, Jumbo Frames support, teaming support, LACP support, e-mail notification, cloud backup
- Encryption Algorithm
- SSL, TLS
- Expansion Bays
- 12 x hot-swap
- 6 x Ethernet 1000Base-T - RJ-45
- Wake on LAN, built-in 3 cooling fans
- UL, BSMI, cUL, CB, FCC, RoHS
- Power Device
- Internal power supply
- Installed Qty
- 2
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- Power Provided
- 549 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
- Power Factor Correction
- OS Required
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
