TrioNAS LX U600Q is Qsan's first unified storage system that integrates NAS (Network Attached Storage) and SAN (Storage Area Network) into one chassis. The unified storage system can provide both file-level data access and block-level data access at the same time. Users can enjoy the benefits of consolidate data network and storage network together.
- Qsan TrioNAS LX U600Q-S316 - NAS server - 48 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet / 10 Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 3U
- Total Storage Capacity
- 48 TB
- Installed Devices / Modules Qty
- 16 (max)
- 44.6 cm x 49.95 cm x 13 cm
- Storage Controller
- RAID SATA 6Gb/s / SAS 6Gb/s RAID RAID 0, 1, 5, 6, 10, 50, 60
- Networking
- 10Mb LAN, 100Mb LAN, GigE, 10 GigE
- RAM
- 8 GB
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- SunSoft Solaris, Apple MacOS, Red Hat Linux 5.0, Red Hat Linux 6.0 or later, Microsoft Windows
- 3-year warranty
- NAS server
- Host Connectivity
- Enclosure Type
- 48 TB
- 16 (max)
- 44.6 cm
- 49.95 cm
- 13 cm
Processor / Memory
- RAM
- 8 GB (installed) / 16 GB (supported) - DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s / SAS 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
Hard Drive
- HDD
- Data Link Protocol
- NTP, DHCP
- Remote Management Protocol
- HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), WINS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
- Hardware compression, trunking, LDAP support, VLAN support, Jumbo Frames support, Samba support, static IP mode, Thin Provisioning, teaming support, Link Aggregation Control Protocol (LACP), cloud backup, SFTP client
- Encryption Algorithm
- SSL, TLS
- IEEE 802.3ad (LACP)
- Expansion Bays
- 16 x hot-swap
- 3 x Ethernet 1000Base-T - RJ-45 , 2 x Ethernet 10Gb
- Built-in 2 cooling fans, deduplication
- UL, BSMI, cUL, ICSA Antivirus, CB, FCC, RoHS
- Power Device
- Internal power supply
- Installed Qty
- 2
- Voltage Required
- Power Provided
- 550 Watt
- 80 PLUS Certification
- 80 PLUS Gold
- Power Factor Correction
- OS Required
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
