AegisSAN LX P400Q, boasting Intel Xeon processor, is a high availability RAID system offering high performance and supporting up to 256 SAS & SATA drives. AegisSAN LX P400Q storage features QiSOE (Qsan hardware iSCSI offload engine) and hardware RAID to boost performance and provide superior IOPS & throughput to process tremendously huge amount of random access data.
Dual active RAID controllers, redundant power supplies, fan modules, and battery backup modules as well as JBOD expansion - all these included in Qsan's P400Q make the iSCSI RAID storage a high availability system.
For better data protection, the top-notch disk array offers copy-on-write snapshot (QSnap), remote replication (QReplica), and battery backup module (BBM) features. It also delivers multiple paths and load balancing functions such as MPIO, MC/S, Trunking, and LACP to better guarantee the reliability and a robust storage environment.
High availability
P400Q iSCSI system is specially designed for high availability applications. The P400Q has fully redundant components including redundant RAID controllers, power supplies, fan modules, battery backup modules and SAS JBOD expansion ports. All of these components are hot-swappable to create a high availability platform and provide non-stop services. Special features in firmware are RAID 6, 60 support, QSnap writable snapshot, Windows VSS support, volume cloning, QReplica remote replication, and volume configuration restoration. All these features are designed to add an extra layer of protection to your valuable data. To raise the bar higher, P400Q can upgrade firmware without system down time. Both firmware image and volume handling are well protected by the redundant RAID controllers. When one RAID controller is down or disconnected, the other RAID controller will take over all tasks immediately and seamlessly. -
Default built-in data protection
The P400Q systems are built-in with Qsan's highly reliable data protection features, from writeable snapshot, volume cloning, to remote replication. Your valuable data can be easily safeguarded and synchronized locally and remotely. In case of accidents, data corruption, virus, and even disasters, the services and applications can be recovered in a very short time. -
Outstanding performance
The P400Q's powerful RAID controllers provide much higher IOPS and throughput than other storage systems within the same segment in the current market. The P400Q can minimize your cost and optimize your investment, simplify storage planning, and integrate more applications.
- Qsan AegisSAN LX P400Q-D460 - hard drive array
- Hard drive array
- Enclosure Type
- Rack-mountable - 4U
- Interface
- iSCSI (1 GbE)
- Installed Devices / Modules Qty
- 60 (max)
- Supported Drives
- SATA-600 / SAS-2
- Built-in Devices
- Status LCD
- Storage Controller
- RAID (SATA 6Gb/s / SAS 6Gb/s) - RAID RAID 0, 1, 3, 5, 6, 10, 30, 50, JBOD, 0+1, 60
- Storage Controller Quantity
- 2
- Hard Drive
- 0 no HDD - hot-swap
- OS Required
- Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Red Hat Enterprise Linux 5, Red Hat Enterprise Linux 6, Oracle Solaris 10, Oracle Solaris 11, Microsoft Windows Server 2012
- Power
- AC 120/230 V
- Power Redundancy
- 48.25 cm x 85 cm x 17.7 cm
- 3-year warranty
- Hard drive array
- Enclosure Type
Chassis
- Built-in Devices
- Status LCD
- Supported Devices / Modules Qty
- 60
- Supported Drives
- SATA-600 / SAS-2
Storage
- HDD Array External Interface
- iSCSI (1 GbE)
- CPU
- Xeon
Storage Controller
- RAID (iSCSI)
- Installed Qty
- 2
- Interface Type
- SATA 6Gb/s / SAS 6Gb/s
- Cache / Buffer Size (Max)
- 8 GB (installed) / 16 GB (max)
- RAID Level
- RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 30, RAID 50, JBOD, RAID 0+1, RAID 60
Storage Controller (2nd)
- Installed Qty
- 2
Hard Drive
- No HDD - hot-swap
- Capacity
- 0
- Expansion Bays
- 60 (total) / 60 (free) x hot-swap - 3.5"
- 12 x Ethernet 1000
- OS Required
- UL, BSMI, cUL, FCC, RoHS
- Power Device
- 3 x internal power supply - hot-plug
- Power Redundancy
- Voltage Required
- AC 120/230 V
- Power Provided
- 700 Watt
- 80 PLUS Certification
- 80 PLUS Gold
- Power Factor Correction
- 48.25 cm
- 85 cm
- 17.7 cm
- Limited warranty - 3 years , Battery replacement - 1 year
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
