QNAP TDS-16489U-SB2 Rackmount 12 Bay
Quicklinx: C2XDWS00 Mfr#: TDS-16489U-SB2
  • Xeon
QNAP furthers its innovation into the field of business servers and introduces the TDS-16489U, a powerful Double Server that integrates an application server and storage server into one chassis. The TDS-16489U is powered by dual Intel Xeon E5 processors with RAM expandable to 1TB and with a server-grade hardware design that optimizes mission-critical tasks and boasts unrivaled performance for Big Data computing. Coupled with Auto Tiering support, 12Gb/s SAS drives and 40GbE readiness, the TDS-16489U performs as an efficient, scalable and unrivaled unified and tiered storage solution for businesses to fulfill cross-platform file sharing, backups, iSCSI & virtualization applications, and everyday practical business needs.
  • Independent SAS 12Gb/s controller increases I/O performance
    Instead of using a SAS controller with expanders to utilize the full capacity of supported drives on a single controller, the TDS-16489U adopts multiple SAS controllers to streamline the architecture with improved connectivity and performance. The TDS-16489U has three LSI 12Gb/s SAS controllers, with each controller supporting 7 ports of 12Gpbs SAS, for connectivity with up to 16 HDDs and 4 SDDs, ensuring each controller can fully utilize the maximum bandwidth to optimize performance and reliability.
  • Graphic card support for virtualization
    PCIe Gen.3 x 16 slot supports AMD Radeon R7 and R9 Series Graphics Cards for GPU pass through to virtualization applications. The IOMMU allows the attached AMD GPU to be given to specific virtual machines to power the image and motion processing from the guest OS when running multiple virtual machines for graphic applications.
  • 10 / 40GbE card support
    The TDS-16489U is a 40GbE-ready solution for maximizing performance via iSCSI or NFS protocols to tackle potential bottlenecks for dramatically-changing and loaded virtualization computing environments.
  • PCIe SSD NVMe for cache acceleration
    NVMe (Non-Volatile Memory Express) is an advanced interface/protocol developed for SSDs attached through the PCIe bus. The TDS-16489U supports PCIe SSD NVMe to provide up to 10 times faster IOPS performance and to decrease I/O latency 3 times, improving the overall workflow of random IOPS demanding applications.
  • 12Gb/s SAS HBA support
    A 12Gb/s SAS HBA can be inserted to provide two 12Gb/s mini SAS interfaces for connecting 12Gb/s SAS-enabled expansion enclosures (REXP-1620U-RP and REXP-1220U-RP) for future-proof scalable storage deployment.
  • 4 x 2.5" SSD for caching
    The TDS-16489U features an extra four 2.5" disk trays at the rear to provide SSD caching without taking space from hard drives. By installing high-performance SSDs, the IOPS performance of storage volumes can be remarkably boosted, making it ideal for random IOPS demanding applications such as databases and virtualization.
  • IPMI helps ease server management
    IPMI (Intelligent Platform Management Interface) supports intelligent system monitoring, controlling, and hardware logs for TDS-16489U platform status such as system temperatures, voltages and fans. IPMI operates independently from the QTS operating system to allow administrators to remotely manage the TDS-16489U even when the system is powered down. IPMI provides a web-based management interface, supports power-down and rebooting from remote control and hardware monitoring and logs.
  • Built-in 4 x 10GbE SFP+ ports
    10GbE networks greatly benefit virtualization applications, data backup/restoration and massive data transmission. The TDS-16489U features four 10GbE SFP+ ports which can optimize system performance and assist businesses to flexibly build virtualization environments and increase productivity.
QNAP TDS-16489U-SB2 - NAS server
NAS server
Host Connectivity
Gigabit Ethernet / 10 Gigabit Ethernet
Enclosure Type
Rack-mountable - 3U
0 (installed) / 20 (max)
44.4 cm x 74.4 cm x 13.08 cm
22.42 kg ()
United States
2 x Intel Xeon E5-2630V3 2.4 GHz (8-core)
Storage Controller
RAID SATA 6Gb/s / SAS 12Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare
10Mb LAN, 100Mb LAN, GigE, 10 GigE
RAM
128 GB
Power Redundancy
Storage Operating System
QNAP QTS 4.2
NAS server
Host Connectivity
Enclosure Type
Rack-mountable - 3U
Total Storage Capacity
0 GB
44.4 cm
74.4 cm
13.08 cm
22.42 kg ()
United States
Processor / Memory
Processors Installed
Number of Cores
8-core
Max Supported Qty
2
RAM
128 GB (installed) / 1 TB (supported) - DDR4
Storage Controller
RAID
Interface Type
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
Network / Transport Protocol
TCP/IP
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
Trunking, LDAP support, wake on LAN (WOL), Syslog support, dynamic DNS server, manageable, E-mail alert, print server, IPv6 support, proxy server, backup server, file sharing, event log, Access Control List (ACL) support, SSH support, Jumbo Frames support, DHCP server, FTP server, SMS alert, Domain Controller, reset button, bandwidth control, IPv4 support, surveillance station, teaming support, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, signage station
Encryption Algorithm
SSL, TLS, FIPS 140-2, 128-bit AES, 256-bit AES
UPnP
Expansion Bays
16 (total) / 16 (free) x hot-swap - 3.5" , 4 (total) / 4 (free) x internal - 2.5"
Expansion Slots
16 (total) / 8 (free) x DIMM 288-pin , 3 (total) / 3 (free) x PCI Express 3.0 x8 , 1 (total) / 1 (free) x PCI Express 3.0 x16
4 x Ethernet 10Gb - SFP+ , 2 x Ethernet 1000Base-T - RJ-45 , 4 x USB 3.0 - Type A , 1 x management - RJ-45 , 1 x management - DB-9 , 1 x VGA - HD-15
2 x network cable
Audible alarm, built-in 4 cooling fans
FIPS 140-2
Internal power supply
Installed Qty
2
Max Supported Qty
2
Power Redundancy
362.86 Watt
Power Provided
650 Watt
QNAP QTS 4.2
Sound Emission
64.8 dB
