QNAP EJ1600-V2 16 Bay NAS Rack Mountable
Quicklinx: D8BBWS00 Mfr#: EJ1600-V2
The EJ1600 v2 expansion enclosure is designed for expanding the storage space on a QNAP Enterprise ZFS NAS by connecting multiple expansion enclosures via high-speed mini SAS cables. Featuring a 12 Gbps SAS interface on the chassis, the EJ1600 v2 ensures fast data passthrough from 12 Gbps SAS-enabled Enterprise ZFS NAS. This is especially useful for virtualization applications and large data applications that require high-performance interconnection, such as video surveillance, archiving large data, and TV broadcast storage, to provide businesses with optimized efficiency and maximized ROI. The EJ1600 v2 connects to the Enterprise ZFS NAS via the dual path mini-SAS design to sustain continuous operations even if an external JBOD cable is disconnected.
  • Efficient power redundancy
    With a 1+1 power redundancy scheme and dual internal power supplies, the QNAP EJ1600 v2 ensures continuous operation, even in the event of a power supply failure. This feature is crucial for maintaining data integrity and availability in mission-critical environments.
  • Versatile expansion options
    The EJ1600 v2 offers flexible storage solutions with its hot-swap expansion bays that support both 2.5" and 3.5" drives. This versatility allows for easy scalability and maintenance, accommodating a wide range of storage requirements.
  • Optimized for reliability
    Designed to operate in environments with a humidity range of 5 - 95% (non-condensing), the EJ1600 v2 is built to withstand diverse operational conditions, ensuring reliable performance and longevity.
QNAP EJ1600 v2 - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 3U
0 (installed) / 16 (max)
Supported Drives
SAS-3
Built-in Devices
Led panel
Hard Drive
No HDD
AC 120/230 V - 50/60 Hz
Power Redundancy
44.62 cm x 61.8 cm x 13.2 cm
24.11 kg
Storage enclosure
Enclosure Type
Rack-mountable - 3U
Chassis
Built-in Devices
Led panel
0
Supported Devices / Modules Qty
16
Supported Drives
SAS-3
CPU
No CPU
Hard Drive
No HDD
Expansion Bays
16 (total) / 16 (free) x hot-swap - 2.5" / 3.5" shared
2 x SAS 6Gb/s (input) - 36 pin 4x Mini SAS HD (SFF-8644) , 2 x SAS 6Gb/s (output) - 36 pin 4x Mini SAS HD (SFF-8644) , 4 x serial (management) - 9 pin D-Sub (DB-9) , 2 x SAS 6Gb/s (reserved) - 36 pin 4x Mini SAS HD (SFF-8644)
Hot-swappable fans, lockable tray
1 x SFF-8644 to SFF-8644 SAS cable - 50 cm
FCC Class A certified, VCCI, BSMI, EN 60950, EN55022, EN55024, CB, ISO 7779, LVD
E2 Series rail kit, 64 x flat head screws (for 2.5" HDD), 64 x flat head screws (for 3.5" HDD), 2 power cords, 16 x HDD tray stickers
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
344.19 watt
Power Provided
450 watt
44.62 cm
61.8 cm
13.2 cm
24.11 kg
Sound Emission
53.5 dB
