QNAP furthers its innovation into the field of business servers and introduces the TDS-16489U, a powerful Double Server that integrates an application server and storage server into one chassis. The TDS-16489U is powered by dual Intel Xeon E5 processors and with a server-grade hardware design that optimizes mission-critical tasks and boasts unrivaled performance for Big Data computing. Coupled with Auto Tiering support, 12Gb/s SAS drives and 40GbE readiness, the TDS-16489U performs as an efficient, scalable and unrivaled unified and tiered storage solution for businesses to fulfill cross-platform file sharing, backups, iSCSI & virtualization applications, and everyday practical business needs.
Server-grade hardware design, robust, reliable & innovative
Suited for enterprise environments which demand the highest performance, simplified IT management, uninterrupted service, and optimized virtualization environments, the TDS-16489U is designed with high-standard hardware specifications to meet those needs. -
Dual processors for big data computing
The TDS-16489U features dual Intel Xeon E5processors to drive performance-demanding Big Data computing capabilities for complex, high-demanding workloads. -
PCIe SSD NVMe for cache acceleration
NVMe(Non-Volatile Memory Express)is an advanced interface/protocol developed for SSDs attached through the PCIe bus. The TDS-16489U supports PCIe SSD NVMe to provide up to 10 times faster IOPS performance and to decrease I/O latency 3 times, improving the overall workflow of random IOPS demanding applications.
- QNAP TDS-16489U-SA1 - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet / 10 Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 3U
- Installed Devices / Modules Qty
- 0 (installed) / 20 (max)
- 44.4 cm x 74.4 cm x 13.08 cm
- 22.42 kg ()
- Processor
- 2 x Intel Xeon E5-2620V3 2.4 GHz (6-core)
- Storage Controller
- RAID SATA 6Gb/s / SAS 12Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare
- Networking
- 10Mb LAN, 100Mb LAN, GigE, 10 GigE
- RAM
- 64 GB
- Power Redundancy
- Storage Operating System
- QNAP QTS 4.2
- NAS server
- Host Connectivity
- Enclosure Type
- Total Storage Capacity
- 0 GB
- 44.4 cm
- 74.4 cm
- 13.08 cm
- 22.42 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- 6-core
- Max Supported Qty
- 2
- RAM
- 64 GB (installed) / 1 TB (supported) - DDR4
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s / SAS 12Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
- Data Link Protocol
- TCP/IP
- Remote Management Protocol
- SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
- Trunking, LDAP support, wake on LAN (WOL), Syslog support, dynamic DNS server, manageable, E-mail alert, print server, IPv6 support, proxy server, backup server, file sharing, event log, Access Control List (ACL) support, SSH support, Jumbo Frames support, DHCP server, FTP server, SMS alert, Domain Controller, reset button, bandwidth control, IPv4 support, surveillance station, teaming support, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, signage station
- Encryption Algorithm
- SSL, TLS, FIPS 140-2, 128-bit AES, 256-bit AES
- UPnP
- Expansion Bays
- 16 (total) / 16 (free) x hot-swap - 3.5" , 4 (total) / 4 (free) x internal - 2.5"
- Expansion Slots
- 16 (total) / 8 (free) x DIMM 288-pin , 3 (total) / 3 (free) x PCI Express 3.0 x8 , 1 (total) / 1 (free) x PCI Express 3.0 x16
- 4 x Ethernet 10Gb - SFP+ , 2 x Ethernet 1000Base-T - RJ-45 , 4 x USB 3.0 - Type A , 1 x management - RJ-45 , 1 x management - DB-9 , 1 x VGA - HD-15
- Cables Included
- 2 x network cable
- Audible alarm, built-in 4 cooling fans
- FIPS 140-2
- Power Device
- Internal power supply
- Installed Qty
- 2
- Max Supported Qty
- 2
- Power Redundancy
- 362.86 Watt
- Power Provided
- 650 Watt
- QNAP QTS 4.2
- Sound Emission
- 64.8 dB
