PSA Parts Main Battery Pack 11.1v 4400mA
Quicklinx: 6LT4WS00 Mfr#: CBI2060A
This high quality internal battery is a 6 cell main battery pack. Guaranteed to meet or exceed the original manufacturer's specification for the CBI2060A internal battery. You can get extra performance using CBI2060A.
PSA Main Battery Pack - laptop battery - Li-Ion - 4400 mAh
Laptop battery
316 g
Lithium Ion 6-cell - 4400 mAh
Battery Form Factor
Internal
20.2 cm x 4.5 cm x 2.1 cm
1-year warranty
Fujitsu AMILO Pa 1510, Pa 1510-10, Pa 1510-10 MCE, Pa 1510-10P, Pa 1510-11, Pa 1510-11P, Pa 1510-B5202, Pa 1510-B5203, Pa 2510, Pa 2510 7007, Pa 2510 7008, Pa 2510-11P, Pa 2510-12P, Pa 2510-14P, Pa 2510-23P, Pa 2510-24P, Pa 2510-25P, Pi 1505, Pi 1505-10P, Pi 1505-11
Laptop battery
Battery Enclosure Type
Internal
6-cell Lithium Ion
Voltage Provided
11.1 V
4400 mAh
Limited warranty - 1 year
20.2 cm
4.5 cm
2.1 cm
316 g
