Dicota Multi Roller SCALE 14-15.6" - Black
Quicklinx: GWZ1WS00 Mfr#: D31441-RPET
Device Type: Laptop
Type: Carry Case
Device Screen Size: 15.6
Colour: Black
20 In Stock
£80.82 ex VAT
£96.98 inc VAT
Lived sustainability with a clear conscience - SCALE's family of products is manufactured from recycled PET and is kind to the environment. Consistent recycling helps to conserve resources. The Multi Roller SCALE is the intelligent trolley for environmentally-conscious professionals. Designed for daily use and equipped with practical functions that make your life easier.
Your notebook is triple protected: with High-Density Foam (HDF) padding, a fastening strap and a divider for fixing the device in the lockable notebook compartment, and reinforced frame. Even your tablet can be safely stored in the padded slip pocket. The generous main compartment offers plenty of storage space for clothing and other luggage. Functional fastening straps as well as an additional slip in pocket for documents establish order in the interior. The spacious front compartment with a practical and easy-access workstation for you mobile accessories allows you to organize your personal items with holders for items such as pens, business cards, IDs and smartphone. The reinforced bottom part, interchangeable quality-wheels, a robust two-stage telescopic handle made of high-class aluminum and a comfortably molded, riveted carry handle assure long-lasting transportation comfort.
DICOTA Multi Roller SCALE - notebook carrying case
Notebook carrying case
Product Material
600D PET
42 cm x 22.5 cm x 35 cm
2.4 kg
Notebook Compatibility
15.6"
Padded, reinforced bottom
Carrying Strap
Top carry handle
Telescopic Handle / Wheels
Product Material
600D PET
42 cm
22.5 cm
35 cm
2.4 kg
15.6"
Notebook Compatibility Dimensions
38.5 cm x 26.5 cm x 3.5 cm
Additional Compartments
Mobile phone, documents, pens, clothing, business cards, ID card, tablet
Carrying Strap
Top carry handle
Wheels Qty
2
Limited warranty: - 2 years
Device Type: Laptop
Type: Carry Case
Colour: Black
Brand: Dicota
