Dicota Portable Laptop/Tablet Stand
Quicklinx: GQ4KWS00 Mfr#: D31889
More than 50 In Stock
£20.14 ex VAT
£24.16 inc VAT
Adjust your device to the best position. The stand has seven height levels. This helps to correct posture to allow you to work throughout the entire day without any problems.
Universally compatible with devices from different manufacturers and devices of different sizes. The stand is made from high-quality aluminum and has heat-reducing properties to prevent the device from over-heating. The silicone pads ensure that the device does not slip off the stand or get scratched. Folds flat, easy to store and transport.
DICOTA - notebook / tablet stand
Notebook / tablet stand
Grey
Product Material
Aluminium alloy
26.5 cm x 16 cm x 6 cm
341 g
Foldable, 7 step adjustable height, anti-slip silicone pad
Product Material
Aluminium alloy
26.5 cm
16 cm
6 cm
341 g
Grey
Limited warranty: - 2 years
Brand: Dicota
