Promethean Promethean Active Slate 60 & A
Quicklinx: 7BFKWS00 Mfr#: ACTIVSLATE60-HU
In the ActivClassroom, nothing is static - subjects, lessons and especially participants come alive. And while students enjoy participating by coming to the ActivBoard, teachers also want connection and freedom of movement - teaching from student desks, debating from the four corners of the room, directing the lesson from inside group discussions. ActivSlate makes dynamic, interactive classroom experiences everyday occurrences by giving anyone who wishes to participate control of the ActivBoard from anywhere in the ActivClassroom. A wireless, fully integrated, notebook-sized tablet, ActivSlate uses the same ActivPens as the ActivBoard, is small enough to sit on a student desk, and is light enough to be carried into any discussion.
Promethean ACTIVslate 60 - digitiser - 2.4 GHz
Digitiser
Wireless - 2.4 GHz
28 cm x 4.2 cm x 25.8 cm
0.6 kg
Movement Detection Technology
Electromagnetic
Movement Resolution
1000 ppi
Battery indicator, power saving automatic sleep function
1 x USB charge cable
1
Debian Linux, Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Vista, Ubuntu 9.04, Apple MacOS X 10.4.11 - 10.6.1, Ubuntu 9.10
1-year warranty
Digitiser
28 cm
4.2 cm
25.8 cm
0.6 kg
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 100 m
Electromagnetic
Movement Resolution
1000 ppi
Active Area
19.5 cm x 14.2 cm
ActivPen, ActivHub
UL, FCC
Installed Qty
1
850 mAh
Run Time (Up To)
21 hour(s)
System Requirements Details
Windows XP/Vista/7 - Pentium 4 - 1 GHz - RAM 512 MB - HD 1.5 GB , MacOS X 10.4.11 - 10.6.1 RAM 512 MB - HD 3 GB
Limited warranty - 1 year
2 °C
45 °C
