Draw, write & inspire ideas
Samsung Flip provides users with a smooth and familiar pen to paper writing experience in a variety of available colors, styles and widths. Up to 4 people can write simultaneously, using any object as a writing tool. In addition, users can quickly erase the drawings with finger or palm swipe -
Creating a masterpiece
On brush mode, Samsung Flip recognizes a wide range of thicknesses, ensuring users can create art at the stroke of a brush. Water and oil painting modes allow different styles and textures, while the Flip also gives users a full, vibrant color palette, even allowing flexible color mixing -
Write on any background
Samsung Flip allows users to write on any background source. By simply clicking the note layer button, users can enjoy smooth writing anytime, anywhere on any content displayed, without affecting any work behind the original layer -
Flexible image editing
Bringing versatility to the board. With Samsung Flip, users can quickly and easily select, move, crop, capture, and edit any images. Each Image can also be merged to the roll with just one click of a button, allowing it to be edited or erased -
Suitable for all business needs
Samsung Flip can be used for a wide range of business applications, providing embedded versatile templates. You can use the Flip as a calendar, scheduler, note or checklist board. Samsung Flip perfectly matches any business need, enabling users to utilize the display in various customized ways -
Easy content navigation & protection
Samsung Flip has up to 20 pages of writing space per roll, allowing users to seamlessly scroll through pages. In addition, the Flip ensures that confidential meeting information remains in the right hands. Its reinforced lock system allows users to safeguard sensitive content from view -
Multiple connection options
Users are empowered by the Flip's versatile connection options. USB, HDMI, NFC and screen sharing capabilities enable optimum collaboration and provide interactive content visibility, notation and sharing. The Flip also offers an optional tray as a more powerful connectivity extension -
Synchronized screen viewing
The touch out functionality allows users to sync their personal devices with the Samsung Flip, allowing real-time content sharing and control. Any changes made on the Flip display will be mirrored on the connected device, and vice versa, for efficient collaboration -
Connect from anywhere
The Samsung Flip allows users to connect their PC to the board remotely, meaning any meeting can be started without a PC to avoid delays and ensure efficiency. A Bluetooth keyboard, mouse and speaker can also be connected to the Flip, creating a convenient meeting environment -
Large audience sharing
Users can project content on Samsung Flip to another large digital display in real time, using Wi-Fi network or HDMI out connection. Even connected to a personal device, the Flip display can be shared. This feature is ideal for large meeting environments, delivering information to bigger audiences -
Effortless meeting recap distribution
Following any meeting, users can distribute recaps to all attendees and colleagues, removing the frustration traditionally associated with handwritten meeting notes. Important conversations and content are stored within the Flip in real-time, easily shareable across mobile and digital channels -
Precise visuals with powerful operation
Samsung Flip displays all content in clear UHD picture quality, regardless of the room, creating a compelling meeting environment. Backed by the powerful Tizen 5.0 operating system for a seamless user experience, embedded sensors automatically activate the display when the screen is knocked
- Samsung Flip 2 WM65R WMR Series - 65" LED-backlit LCD display - 4K - for interactive communication
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 65"
- Commercial Use
- Yes - interactive
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Frame Rate & Enhancement Technology
- 60 Hz Refresh Rate
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi, LAN, NFC
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Storage Drive Capacity
- 8 GB
- Storage Capacity
- 8 GB
- USB
- 2 ports
- Included Accessories
- 2 passive pens
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A+
- 181.5 Watt
- Power Consumption (On mode)
- 100 W
- Energy Consumption per Year
- 146 kWh
- Dimensions (WxDxH) - without stand
- 152.22 cm x 6.29 cm x 89.76 cm
- 40 kg
- Product Type
- Energy Class
- Class A+
- 181.5 Watt
- 100 W
- 146 kWh
- Diagonal Class
- 65"
- Commercial Use
- Yes - interactive
- Combined With
- Touchscreen
- Series
- WMR Series
- Operating System
- Linux
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Dimensions
- Without stand
- 152.22 cm
- 6.29 cm
- 89.76 cm
- 40 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Edge-lit LED
- Image Contrast Ratio
- 4000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
- VESA Compatibility
Media Player
- USB Port
- USB Ports Qty
- 2
- Configuration
- ARM Cortex-A72 Quad-Core ( 1.7 GHz ) - 2.5 GB LPDDR4 - 8 GB
- 8 GB
Network & Internet Multimedia
- Connectivity
- Wi-Fi, LAN, NFC
- Connector Type
- 2 x HDMI input , 2 x USB - side , Serial input , LAN
- 2 passive pens
- Cables Included
- USB cable
- CSA, UL, TUV, VCCI, C-Tick, BSMI, GOST, cUL, NEMKO, NOM, SASO, CB, AS/NZS 60950-1, CCC, PSB, IRAM, IEC 60950-1, EN 60950-1, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, RCM, IS13252, VCCI V-3/2010.04 Class A, CNS 14972, GOST 22505-97, CNS 13438 Class A ITE EMI, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, GOST-R 51317, BIS, INMETRO, GB 4943.1-2011, AS/NZS CISPR 22:2009, KCC/EK, EN 55024:1998+A1:2001+A2:2003, EN 55022:2006+A1:2007
- Power Device
- Power supply
- Input Voltage
- Power Consumption Sleep
- 0.5 Watt
- Width (Shipping)
- 169.1 cm
- Depth (Shipping)
- 19.8 cm
- Height (Shipping)
- 105.5 cm
- Weight (Shipping)
- 50.6 kg
- 0 °C
- 40 °C
- 10 - 80%
