Smart Technologies Podium 624 Pro
Quicklinx: DV7DWS00 Mfr#: SP624P
£1,813.24 ex VAT
£2,175.88 inc VAT
The SMART Podium 624 Pro interactive pen display enables a presenter to face an audience while mirroring a connected computer's display to a large format display. The podium includes SMART Meeting Pro software and facilitates interactivity in business boardrooms and auditoriums. The SMART Podium 624 Pro works with your computer and SMART Product Drivers to provide a reliable interactive experience. You can do everything you do at your computer - use SMART Ink, open and close applications, create and edit documents, visit websites, play and manipulate videos and more - just by touching the podium's surface with your finger. Use the pen for precise annotation over presented materials, and you can save your notes in many applications. In addition to the familiar features of other SMART podiums, the HDCP-compliant SMART Podium 624 Pro includes easily accessible buttons, a pen rest, and a stand.
SMART Podium 624 Pro - touchscreen - USB, DVI-I
Touchscreen
Wired - USB, DVI-I
Display
LCD display - 24" - 1920 x 1080
60 cm x 4.6 cm x 35.6 cm
7.2 kg
Multi-Touch
Movement Detection Technology
Electromagnetic / capacitive
Pressure sensitive pen, -/+ 60 levels tilt recognition, battery-free stylus, security lock slot, 60° vertical
AC 120/230 V
Apple MacOS X 10.10, Microsoft Windows 7 / 8 / 8.1 / 10, Apple MacOS X 10.11, Apple macOS Sierra 10.12, Apple macOS High Sierra 10.13
3-year warranty
Touchscreen
60 cm
4.6 cm
35.6 cm
7.2 kg
Input Device
Wired
USB, DVI-I
Multi-Touch
Pressure Levels
2048
Active Area
52.7 cm x 29.7 cm
Display
LCD display
Diagonal Size
24"
Image Aspect Ratio
16:9
Colour Support
16.7 million colours
Native Resolution
1920 x 1080
Image Brightness
210 cd/m²
Image Contrast Ratio
1000:1
Vertical Refresh Rate
60 Hz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+75 / -75
Response Time
32 ms
1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x video - DVI-Analogue/Digital (dual link) input - DVI-I , 1 x video - DVI-Analogue/Digital (dual link) output - DVI-I
Nibs (5 pcs.), stand, nib removal tool, electronic pen, pen tray, stylus tether, pen holder, DVI-D to HDMI cable adapter (2m), VGA to DVI-A cable (2m), USB cable (Type-A to Type-B) (2m), DVI-D to DVI-D cable (2m)
FCC, RoHS, WEEE, REACH, RCM, HDCP 1.4, ISED, CONEG
AC 120/230 V
Power Consumption
40 Watt
Power Consumption Stand by
0.5 Watt
Software Included
SMART Meeting Pro
Shipping Width
70 cm
Shipping Depth
24 cm
Shipping Height
55 cm
Shipping Weight
11.2 kg
Limited warranty - 3 years , Limited warranty - digital pen - 1 year
5 °C
35 °C
30 - 80% (non-condensing)
Brand: Smart Technologies
Price Range Ex VAT: £1500+
