In the ActivClassroom, change is a welcome constant. Students grow and learn, curricula shift, ideas and methods evolve and back again. Education is always seeking what's next, but every classroom has to start somewhere. The ActivBoard 300 Range is a solid foundation for your ever-evolving ActivClassroom then grows with you.
The ActivBoard 300 Range offers a classroom-tough screen, bright color, engaging movement and fixed or adjustable installations. But the ActivBoard 300 Range also features a singular ability to pile on exciting extras as needed. Schools can easily add stereo sound, wireless connectivity and dual-user functionality - whenever the time is right.
This Promethean ACTIVboard 378 Pro comes with a projector of silver.
- Promethean ActivBoard 378 Pro - interactive whiteboard - USB
- Interactive whiteboard
- Connectivity Technology
- Wired - USB
- Display
- Projector
- Movement Detection Technology
- Electromagnetic
- Built-in stereo speakers, low-glare surface
- Cables Included
- 1 x USB cable - external - 5 m
- OS Required
- Microsoft Windows Vista / XP, Apple MacOS X 10.4.11 or later, Ubuntu 8.04
- 3-year warranty
Input Device
- Wired
- Interface
- USB
- Electromagnetic
- Active Area
- 162.8 cm x 117.5 cm
Display
- Projector
- 1 x USB - 4 pin USB Type A
- Included Accessories
- Styluses (4 pcs)
- Cables Included
- UL, FCC
- OS Required
- Limited warranty - 3 years
