The ActivBoard 300 Pro Range is a feature-rich interactive whiteboard that combines color, motion and interactivity with integrated sound and Dual-User functionality. Much more than your typical interactive whiteboard, the ActivBoard 300 Pro Range is a hub of activity. Built-in speakers and a discreet but powerful amplifier add stereo sound to any lesson. Available with fixed mount or motorized height-adjustable stands, short-throw projectors and a durable, classroom-ready surface mean everyone can come to the board. Built in Dual-User capability and with ActivInspire Professional Edition software included means teachers have access to tens of thousands of free lessons and resources at Promethean Planet.
300 Pro Range 78" ActivBoard with Mount System and DLP short throw projector - 2 x Teacher & 2 x Student ActivPen 50 included. Includes access to ActivInspire Professional Edition/Promethean ActivOffice.
- Promethean ActivBoard 378 Pro - interactive whiteboard - USB
- Interactive whiteboard
- Connectivity Technology
- Wired - USB
- Display
- Projector - 1280 x 800
- 186.8 cm x 132.9 cm
- 28 kg
- Movement Detection Technology
- Electromagnetic
- Movement Resolution
- 2730 ppi
- Low-glare surface
- Cables Included
- 1 x USB cable - external - 5 m
- OS Required
- Debian Linux, Ubuntu 9.04, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.4.11 - 10.6.1, Ubuntu 9.10
- 186.8 cm
- 132.9 cm
- 28 kg
Input Device
- Wired
- Interface
- USB
- Electromagnetic
- 2730 ppi
- Active Area
- 162.8 cm x 117.5 cm
- Low-glare surface
Display
- Projector
- Colour Support
- 16.7 million colours
- Native Resolution
- 1280 x 800
- Image Brightness
- 2500 lumens
- Image Contrast Ratio
- 2000:1
- 1 x USB
- Included Accessories
- Wallmount brackets, 2 x ActivPen
- Cables Included
- UL, FCC
- OS Required
- System Requirements Details
- Windows XP/Vista/7 - Pentium 4 - 1 GHz - RAM 512 MB - HD 1.5 GB , MacOS X 10.4.11 - 10.6.1 RAM 512 MB - HD 3 GB
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
