Your basket is empty
Promethean 300PRO Range 78" ActivBoard w/Mount System & DLP Short Throw
Quicklinx: 86L3WS00 Mfr#: ABMTS378PUKDST
£2,037.46 ex VAT
£2,444.95 inc VAT
The ActivBoard 300 Pro Range is a feature-rich interactive whiteboard that combines color, motion and interactivity with integrated sound and Dual-User functionality. Much more than your typical interactive whiteboard, the ActivBoard 300 Pro Range is a hub of activity. Built-in speakers and a discreet but powerful amplifier add stereo sound to any lesson. Available with fixed mount or motorized height-adjustable stands, short-throw projectors and a durable, classroom-ready surface mean everyone can come to the board. Built in Dual-User capability and with ActivInspire Professional Edition software included means teachers have access to tens of thousands of free lessons and resources at Promethean Planet.
300 Pro Range 78" ActivBoard with Mount System and DLP short throw projector - 2 x Teacher & 2 x Student ActivPen 50 included. Includes access to ActivInspire Professional Edition/Promethean ActivOffice.
Promethean ActivBoard 378 Pro - interactive whiteboard - USB
Interactive whiteboard
Wired - USB
Display
Projector - 1280 x 800
186.8 cm x 132.9 cm
28 kg
Movement Detection Technology
Electromagnetic
Movement Resolution
2730 ppi
Low-glare surface
1 x USB cable - external - 5 m
Debian Linux, Ubuntu 9.04, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.4.11 - 10.6.1, Ubuntu 9.10
186.8 cm
132.9 cm
28 kg
Input Device
Wired
USB
Electromagnetic
Movement Resolution
2730 ppi
Active Area
162.8 cm x 117.5 cm
Low-glare surface
Display
Projector
Colour Support
16.7 million colours
Native Resolution
1280 x 800
Image Brightness
2500 lumens
Image Contrast Ratio
2000:1
1 x USB
Wallmount brackets, 2 x ActivPen
UL, FCC
System Requirements Details
Windows XP/Vista/7 - Pentium 4 - 1 GHz - RAM 512 MB - HD 1.5 GB , MacOS X 10.4.11 - 10.6.1 - RAM 512 MB - HD 3 GB
86L3 C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.32
86L3 C2G 5m Select High Speed HDMI with Ethernet In Stock £18.04
86L3 C2G 10m Select High Speed HDMI with Ethernet In Stock £34.61
86L3 C2G 15m Select High Speed HDMI with Ethernet In Stock £46.91
Brand: Promethean
Price Range Ex VAT: 1500+
