Get inspired by the extreme quality of sound with the compact stylish new Prestigio Universal Tablet Stand with BT Wireless Speaker! The stand function makes watching Video streaming both cosy and comfortable and the built-in microphone facilitates comfortable Skype calls and video conferences. Enjoy Real Sound together wherever you are - whether you’re going to the beach, camping or simply to your house, you can enjoy your music wirelessly up to 50 m. Want your speaker to last for a longer time – so more music? Don’t worry. The rechargeable battery lasts up to 6 hours on a single charge. Do you want to leave your device inside while the speaker goes out? No problem. You can play music up to 10 m away from your Bluetooth device. Enjoy simplified Bluetooth® connectivity with NFC. Just touch NFC logos to: power the speaker on, activate Bluetooth®, pair devices and stream music. Rechargeable battery 1150 mAh allows to charge your Smartphones and Tablet PCs.
- Prestigio PBS7 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Speaker Type
- Active
- Continuous Power
- 6 Watt
- Frequency Response
- 20 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth, NFC
- Speaker Details
- Speaker - stereo x 2 - 3 Watt - 20 - 20000 Hz - 4 Ohm - active
- Silver
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable
- 9 cm x 5.29 cm x 20 cm
- 440 g
- 2-year warranty
- Product Type
- Hands-Free Function
- Enclosure Colour
- Silver
Speaker System
- Speaker Type
- Active
- Continuous Power
- 6 Watt
- 20 - 20000 Hz
- Signal-To-Noise Ratio
- 70 dB
- Amplifier
- Integrated
- Bluetooth, Near Field Communication (NFC)
- Transmission Range
- 10 m
- Controls
- Power on/off, volume, play/pause
- Additional Features
- Built-in stand
Speaker System Details
- Speaker Details
- Speaker - stereo x 2 - 3 Watt - 20 - 20000 Hz CFR - 4 Ohm - active
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , DC power output (4 pin USB Type A (power only))
- Included Accessories
- Carrying pouch, audio cable, power adapter
- Power Source
- Battery
- Options
- USB charging
- Rechargeable
- Capacity (Ah)
- 1150 mAh
- Run Time (Up To)
- 6 hour(s)
- 9 cm
- 5.29 cm
- 20 cm
- 440 g
- Limited warranty - 2 years
