Philips Q-Line BDL3230QL 32" 1920x1080 8ms VGA DVI HDMI LED Large Format Display
Quicklinx: DC80WS00 Mfr#: BDL3230QL/00
  • 1080p
Deliver startlingly clear images in a more eco-friendly way. High on performance and reliability, yet low on power consumption, it is ideal for projects where no compromise is accepted.
  • Full HD LED technology
    Picture Quality matters. Regular displays deliver quality, but you expect more. Imagine crisp detail paired with high brightness, incredible contrast and realistic colors for a true to life picture.
  • SmartControl
    SmartControl software suite lets you remotely control and manage your network of displays via RJ45 and RS232C. Easily identify your displays and fine-tune all display settings including resolution, brightness, contrast, video wall configurations and cloning of your settings over your complete network.
  • SmartCMS
    Free and easy-to-use content management system that works exclusively with Philips Sigage Solutions displays to manage your digital signage content. With SmartCMS you can create and schedule your own content over 24 hours every day. Simply create your network, design your content, schedule your playlist and you are ready to play!
  • Integrated HTML5 browser
    Connect and control your content via the cloud with the integrated HTML5 browser. Design your signage content online and connect it with a display or with your complete network. Simply plug in a RJ45 internet cable for network connection, connect the display with the dedicated url-address and you are ready to play your cloud based content.
  • SmartPlayer
    Turn your USB into a true cost effective digital signage device. Simply save your content (video, audio, pictures) on your USB and plug into your display.Create your playlist and schedule your content via the on screen menu, and enjoy your own created playlists anytime, anywhere.
  • Clinical D-image
    D-image helps you to review and diagnose clinical images with consistent and accurate display performance. To achieve reliable clinical interpretations professional displays are factory calibrated to give optimized greyscale standard display performance. D-image helps you to excel in every aspect of patient care.
  • SmartPower
    The backlight intensity can be controlled and pre-set by the system to reduce the power consumption by up to 50%, which saves substantially on energy costs.
Philips BDL3230QL Q-Line - 32" Class (31.5" viewable) LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
32"
Diagonal Size
31.5"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Max Number of Screens
225
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
LAN
PC Interface
DVI, VGA (HD-15)
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
HTML5 support, Clinical D-image
Picture Enhancements
Pixel Shift
Speaker System
2 speakers
DVR
Flash - 8 GB
USB
Remote control, batteries
Voltage
AC 120/230 V
50 Watt
Power Consumption Stand by
0.5 Watt
72.65 cm x 6.36 cm x 42.54 cm
5.2 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
50 Watt
Diagonal Class
32"
Diagonal Size
31.5"
Commercial Use
Series
Q-Line
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
Pixel Shift
Timer Functions
Wake, power on delay
Dimensions
Without stand
72.65 cm
6.36 cm
42.54 cm
5.2 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
Direct-lit LED
Colour Depth
16.7 million colours
Image Contrast Ratio
1400:1
Dynamic Contrast Ratio
50000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.36375 x 0.36375mm
Response Time
8 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish
Backlight Life
50,000 hour(s)
Commercial Features
Smart Control, SmartCMS, One Wire, Smart Collection
Video Wall
225
Stands & Mounts
Flat Panel Mount Interface
100 x 100 mm, 200 x 200 mm
DVR
DVR
Flash - 8 GB
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Media Player
Supported Video Formats
MPEG-4, Xvid, DivX, WMV, ASF, QuickTime, AVI, MKV, MOV, VOB, FLV, TS, M2TS, F4V, DAT, M4V, TRP, WebM, MPG, MPEG, MTS
Supported Audio Formats
MP3, WMA, WAV, AC3, AAC, Ogg Vorbis, AIFF, AMR, M4A
Supported Pictures Formats
BMP, JPG, GIF
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
HDMI , VGA input , DVI-D input , Component video input , Audio line-in , Composite video input , Audio line-in , LAN , Serial output , USB , Audio line-out , Serial input , Remote control input , Remote control output
Batteries
Serial cable , VGA cable
UL, C-Tick, BSMI, GOST, cUL, CCC, CECP, EPA
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Input Voltage
AC 120/230 V
0.5 Watt
Smart power
Limited warranty - 3 years
5 °C
20 - 80%
