Impress with a large diameter display. The Philips D-Line is a high-performance powerhouse for corporate, educational and similar environments that need to go bigger.
Ultra HD resolution
See your signage solutions like never before thanks to four times the resolution of a conventional Full HD display. More pixels provide and image so refined, so lifelike, it's a window to the world. -
Smart power
The backlight intensity can be controlled and pre-set by the system to reduce the power consumption, which saves substantially on energy costs. -
Content protection
Keeping your content up and running is critical for demanding commercial applications. While it is unlikely you will face a content disaster, D-Line provides content protection with an incredible technology that plays back-up content on screen in the event of a media player failure.
- Philips 75BDL4150D D-Line - 75" Class (74.5" viewable) LED-backlit LCD display - 4K - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 75"
- Diagonal Size
- 74.5"
- Commercial Use
- Yes - digital signage
- Platform
- Android
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Input Video Formats
- 480/60p, 720/60p, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i, 2160/30p, 480/30p, 1080/30i, 2160/50p, 2160/60p, 1080/25i, 480/30i, 576/25i, 576/25p
- Max Number of Screens
- 225
- Video Interface
- HDMI
- HDMI Ports Qty
- 3 ports
- Connectivity
- LAN
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- CMND management
- Picture Enhancements
- Motion Compensation, dynamic contrast enhancement, Pixel Shift, 3D Digital Comb Filter, Low Bright
- Speaker System
- 2 speakers
- Storage Capacity
- 64 GB flash
- Supported Memory Cards
- microSD
- USB
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 167.66 cm x 7.38 cm x 95.5 cm
- 54.3 kg
- 3-year warranty
- Product Type
- Diagonal Class
- 75"
- Diagonal Size
- 74.5"
- Commercial Use
- Series
- D-Line
- Platform
- Android
- Operating System
- Android OS 7.1.2
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- Modes
- Portrait mode, landscape mode
- Dimensions
- Without stand
- 167.66 cm
- 7.38 cm
- 95.5 cm
- 54.3 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Image Contrast Ratio
- 1200:1
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pull-Down Compensation
- 3:2, 2:2
- Response Time
- 6 ms
- Display Menu Language
- Danish, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
- Backlight Life
- 50,000 hour(s)
- CMND management
- 3D MA deinterlacing, Smart Insert, Intel OPS compatible, Enhanced Fail Over, picture in picture (no tuner)
Video Wall
- 225
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 600 x 400 mm
- VESA Compatibility
Video Features
- Supported Computer Resolutions
- 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 720 x 400, 1360 x 768, 1920 x 1080, 1280 x 800, 3840 x 2160
Media Player
- Supported Video Formats
- MPEG-4, WMV, ASF, AVI, MKV, VOB, FLV, TS, DAT, WebM, MPG, MPEG
- Supported Audio Formats
- MP3, WMA, AAC, M4A
- Supported Pictures Formats
- BMP, JPG, PNG, JPEG
- microSD
- USB Port
- Configuration
- ARM Cortex-A73 Dual-Core + ARM Cortex-A53 Dual-Core - 4 GB - 64 GB flash - Mali T860 MP4
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- Connector Type
- DisplayPort input , 3 x HDMI input , DVI-D input , VGA input , DisplayPort output , Audio line-out , Audio line-in , RS-232 input , RS-232 output , LAN , USB , USB , USB
- Batteries
- Cables Included
- HDMI cable , IR extender cable - 1.8 m , Serial cable
- FCC Class B certified, UL, C-Tick, BSMI, GOST, cUL, CB, RoHS
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Smart power
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
