Philips Hue Wireless Dimmer Kit EU (E27)
Quicklinx: CHZYWS00 Mfr#: 929001137007
Wireless dimming
Enjoy smooth wireless dimming. The Philips Hue Wireless dimming kit combines a clever wireless dimmer and a Philips Hue White LED bulb. No installation needed. Just place the switch anywhere you like and use it as a remote control.
Comfort dimming
Just screw in the light bulb and turn on the light.
Place it anywhere
Place anywhere you need a light switch.
Use as a remote control
Wireless switch and remote control in one.
Control multiple lights with one switch
Control up to 10 lights at once with one switch.
Connect to your Philips Hue system
Connect to Philips Hue and discover the possibilities.
Installation-free dimming
With this installation-free kit, all you have to do is screw the Hue White LED bulb into your standard fixture and switch on the light. You can immediately control your light using the battery-powered Hue Dimmer switch. No need to call an installer.
Fast and simple installation
The battery-powered Hue Dimmer switch can be used as a standard wall switch. You can place it anywhere you want, using screws or the adhesive tape on the back plate of the switch. Installation is fast and simple, with no wires and no hassle.
Easy wireless control
The switch is magnetic and can be removed from the back plate. This means you can also use the Philips Hue Dimmer switch as a remote control for your light with an indoor range of up to 12 metres.
Once you're set up with your Philips Hue Wireless dimming kit, you can easily connect more Philips Hue lights to the dimmer switch. Link up to 10 Philips Hue lights to your dimmer switch and control them simultaneously.
The Wireless dimming kit belongs to the Philips Hue family, so it can be seamlessly integrated with other Philips Hue lights. If you install a Hue Bridge in your home, you can integrate your Philips Hue Wireless dimming kit into your system via the Philips Hue app, for even more experiences today and in the future. Control your lights from your smartphone or tablet and set timers, notifications, alarms and more.
  • Installation free dimming
    With this installation free kit, all you have to do is screw in the Hue White LED bulb in your standard fixture and switch on the light. You can immediately control your light using the battery-powered Hue Dimmer switch. No need to call an installer.
  • Fast and simple installation
    The battery-powered Hue Dimmer switch can be used as a regular wall switch. You can place it anywhere you want, using screws or the adhesive tape on the back plate of the switch. It is a fast, simple installation with no wires and no hassle.
  • Easy wireless control
    The switch is magnetic and can be removed from the back plate. This allows you to also use the Philips Hue Dimmer switch as a remote control for your light with an indoor range of up to 12 meters.
  • Control up to 10 lights
Philips Hue Wireless Dimming Kit - wireless lighting set - LED light bulb - shape: A60 - E27 - 9.5 W - warm white light - 2700 K
Wireless lighting set
Light Source Type
LED light bulb
Supported Light Bulbs Qty
10
Dimmer
Shape
A60
Socket Type
E27
Wattage
9.5 W
Energy Efficiency Class
A+
Colour of Illumination
Warm white light
Colour Temperature
2700 K
Luminous Power
806 lumens
Beam Angle
180 degree(s)
Platform
Hue
Communications Technology
Zigbee
AC 100 - 240 V
Frequency Required
50 - 60 Hz
10
Dimmer
Wireless, ZigBee Light Link, upgradable firmware
Light Source
LED light bulb
Shape
A60
Socket Type
E27
Wattage
9.5 W
A+
Warm white light
Colour Temperature
2700 K
Colour Rendering Index
80
Luminous Power
806 lumens
Beam Angle
180 degree(s)
Lifetime
25000 hours
Switch Cycles
50000
Upgradable firmware, instant full light
Power Requirements
AC 100 - 240 V
Frequency Required
50 - 60 Hz
1 x CR2450
Internet of Things (IoT)
Platform
Hue
Zigbee
Dimmer switch, battery
Warranty
2 years
Dimensions & Weight Details
Dimmer switch - width: 35 mm x depth: 11 mm x height: 92 mm - 37 g , Light bulb height: 110 mm x diameter: 61 mm
-10 °C
45 °C
