Philips Hue White 15.5W A67 E27 Bulb
Quicklinx: GX0HWS00 Mfr#: 929002334904
Get bright lighting for spaces such as the garage or kitchen, as well as softer light for any room, with a Philips Hue White A67 bulb, which offers a powerful 1,600 lumen output (equivalent to 100 W) and wireless dimming. Connect to a Hue Bridge to unlock the full suite of smart lighting features.
  • Bluetooth enabled
  • Hue Bridge enabled
  • Up to 1600 lumens*
  • Powerful, bright white light
  • Instant control via Bluetooth
  • Add Hue Bridge to unlock more
  • Control up to 10 lights with the Bluetooth app
    Philips Hue with Bluetooth is the easiest way to get started with smart lighting. Set the mood instantly with Bluetooth-enabled LED bulbs and the Hue Bluetooth app, which allows you to control up to 10 lights in a room.
  • Control lights with your voice
    Activate hands-free help in any room with Bluetooth voice-activated smart lights. Simply pair your Hue lights with any compatible Amazon Echo or Google Home device to enjoy the convenience of managing your smart lights with just your voice.
  • Set the right mood with soft white light
    Enjoy the perfect shade of warm white light to complement any decor and to help you in your daily tasks. Completely dimmable, Hue White smart lighting is the perfect stepping stone to setting the right mood in your home (high lumen)
  • Unlock full suite of smart light features with Hue Bridge
    Add a Hue Bridge to your Bluetooth-controlled set-up to make your smart lighting system even smarter. With the Hue Bridge, you can add up to 50 lights - including your existing Bluetooth-capable lights - and smart accessories throughout your entire home, as well as tap into upgraded features such as away-from-home control.
    The High Lumen bulb provides a powerful white light that is bright enough to fully illuminate the kitchen, garage or any other room where you need functional lighting. With 1600 lumen output of brilliant light, it's no surprise that it's Philips Hue's brightest bulb.
Philips Hue White - LED light bulb - shape: A67 - E27 - 15.5 W - soft white light - 2700 K
Light Source Type
LED light bulb
Shape
A67
Socket Type
E27
Wattage
15.5 W
Wattage Equivalent
100 W
Energy Efficiency Class
F
Colour of Illumination
Soft white light
Colour Temperature
2700 K
Luminous Power
1600 lumens
Dimmable
Intelligent Assistant
Alexa
Platform
Apple HomeKit, Google Home, Hue
Communications Technology
Bluetooth, Zigbee
AC 220 - 240 V
Light Source
LED light bulb
Shape
A67
Socket Type
E27
Wattage
15.5 W
Wattage Equivalent
100 W
F
Energy Consumption per 1000h
16 kWh
Soft white light
Colour Temperature
2700 K
Colour Rendering Index
80
Luminous Power
1600 lumens
Dimmable
Lifetime
25000 hours
Upgradable firmware, instant full light, Android compatible, iOS compatible, remote controlled
Power Requirements
AC 220 - 240 V
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Communications Type
Product-to-product
Bluetooth, Zigbee
Alexa
Package
Box
Warranty
2 years
Diameter
67 mm
Length
131 mm
172 g
-10 °C
45 °C
