Philips Hue White 10.5W A60 E27 Starter Kit
Quicklinx: GVYDWS00 Mfr#: 929002468403
Philips Hue White ambiance can help you to fall asleep and wake up gently. It can energize you and help you to concentrate, read and relax. Set the right ambiance with a range of white light, from cool daylight to relaxing warm white light.
  • Control it your way
    Control your lights from your smartphone or tablet, or add switches to your system to activate your lights.
  • Create your ambiance with warm white to cool daylight
    Set the right ambiance for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, no matter if it's the crisp white light reminding you of a spring breeze, the warm white light of a summer sun, or the ice cool daylight of winter.
  • Energize yourself
    Skip your morning coffee and get ready for the day with cool, bright white daylight that helps to energize your body and mind. Perfect for those moments when your batteries are running low and you need a kickstart.
Philips Hue White ambiance Starter Kit - wireless lighting set - LED light bulb x 3 - shape: A60 - E27 - 8 W - warm white to cool daylight - 2200-6500 K
Wireless lighting set
Light Source Type
3 x LED light bulb
Supported Light Bulbs Qty
50
Dimmer
Shape
A60
Socket Type
E27
Wattage
8 W
Wattage Equivalent
75 W
Energy Efficiency Class
F
Colour of Illumination
Warm white to cool daylight
Colour Temperature
2200-6500 K
Luminous Power
806 lumens
Intelligent Assistant
Cortana, Google Assistant, Alexa
Platform
Apple HomeKit, Google Home, Hue
Communications Technology
Bluetooth, Zigbee
AC 220 - 240 V
50
Dimmer
Android compatible, iOS compatible, 16 million changeable colours, app-controlled, lighting schedules, power on/off timer, voice control
Light Source
3 x LED light bulb
Shape
A60
Socket Type
E27
Wattage
8 W
Wattage Equivalent
75 W
F
Energy Consumption per 1000h
8 kWh
Power Factor
0.5
Colour Temperature
2200-6500 K
Luminous Power
806 lumens
Lifetime
25000 hours
Switch Cycles
50000
Instant full light
Power Requirements
AC 220 - 240 V
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Compatible Application
Philips Hue App
Bluetooth, Zigbee
Power adapter, network cable, Hue switch, Hue bridge
Package
Box
Warranty
2 years
549 g
Dimensions & Weight Details
Light bulb - width: 60 mm x depth: 60 mm x height: 110 mm - 72 g , Wireless bridge height: 2.6 cm , Dimmer switch - width: 3.5 cm x depth: 1.1 cm x height: 9.2 cm - 37 g , Wall plate - width: 7 cm x depth: 0.6 cm x height: 7.6 cm
21.9 cm x 17.6 cm x 14 cm / 1.01 kg
-20 °C
45 °C
