Philips hue combines brilliant LED light with intuitive technology. It will surely change the way you use light. Forever. Experiment with shades of white, from invigorating blue/white to cozy yellow/white. Or play with all the colors in the spectrum. Hue can wake you up. Help protect your home. Relive your favorite memories. Improve your mood. Even keep you informed about the weather. Not just stunning, hue is smart too. And it's tailored for you.
- Philips Hue White and color ambiance - LED light bulb with reflector
- Light Bulb Type
- Socket Type
- GU10
- Wattage
- 6.5 W
- Colour of Illumination
- 16 million colours
- Colour Temperature
- 2000-6500 K
- Luminous Power
- 250 lumens
- Beam Angle
- 160 degree(s)
- Dimmable
Light Bulb
- Socket Type
- GU10
- Wattage
- 6.5 W
- 2000-6500 K
- Luminous Power
- 250 lumens
- Luminous Efficacy
- 38 lm/W
- Beam Angle
- 160 degree(s)
- Dimmable
- Lifetime
- 25000 hours
- Upgradable firmware, instant full light
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Platform
- Hue
- Package
- Box
- Warranty
- 2 years
- Diameter
- 50 mm
- Length
- 71 mm
- 0 °C
- 40 °C
