- Philips Hue White and Color Ambiance Compact Gradient Play - light bar - LED - tube - white
- Product Type
- Light bar - tube
- Light Source Type
- LED
- Light Cover Type
- Diffuser
- Dimmer
- Cable Length
- 2 m
- White
- Luminous Power
- 1540 lumens
- Voltage Required
- AC 100 - 240 V
- Frequency Required
- 50 - 60 Hz
- Product Type
- Light bar
- Shape
- Tube
- Light Cover Type
- Diffuser
- Dimmer
- Cable Length
- 2 m
- Protection class III, replaceable lighting module, Hue Sync technology, 40" - 55" TVs compatible
Light Source
- LED
- Built-in LED Lamp
- Luminous Power
- 1540 lumens
- Lifetime
- 25000 hours
Power Requirements
- Voltage Required
- AC 100 - 240 V
- 50 - 60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Required
- Hub Compatibility
- Philips Hue Bridge
- Product Material
- Aluminium
- Body Colour
- White
- Included Accessories
- Power supply
- Package
- Box
- IP20
- Warranty
- 2 years / 30 days return
- 3.1 cm
- 3.4 cm
- Length
- 87.7 cm
- Shipping Dimensions (WxDxH) / Weight
- 12 cm x 90.1 cm x 10 cm / 1.25 kg
