Philips Hue Iris Clear - Single
Quicklinx: CHZ6WS00 Mfr#: 915004315901
Light your room to set the mood with the unique Friends of Hue LivingColors Iris, from Philips. Designed to work with Philips Hue systems, this wireless-enabled mood light connects to your Wi-Fi to allow you you to control the atmosphere in your room through the Philips Hue app for iOS and Android. Hue lamps and light bulbs can be grouped together so you can set the mood in a room in one go, with up to 50 lights on one network.
Colour your life
With 16 million colour variations to choose from, you can set Iris to the mood that suits you, so you can wash your walls with a blue ocean glow or illuminate a favourite feature. Colours can be saved as 'Scenes', so you can revisit your favourites, or you can choose from the available presets. These 'light recipes' have been proven to create the perfect atmosphere for your needs. The 'Reading' recipe is ideal for curling up with a book, while 'Relax' provides a soothing glow. 'Concentrate' will help you stay alert when working, while 'Energise' bathes you in vibrant lights to revitalise you.
Programmable
Iris works as more than just a colourful lamp. It can be tailored to your life, with alarms, timers and alerts, so you can set Hue to wake you up with a soft sunrise glow, or to turn all of your Hue lights off at bedtime. Hue lights can flash at you to let you know when your food is ready to come out of the oven, or to let you know when your favourite TV show is starting. You can set your lights to come on when you're away, to deter thieves, or control them remotely via the portal, from anywhere in the world. Geofencing technology can be used to turn your Hue lights on as you enter the door. Hue can even be linked to data feeds via the IFTTT (If This Then That) service, to give you a visual alert when you get an important email or when the weather changes.
Apps to help you unlock more
With additional iOS and Android apps, you can get even more out of your Hue. Ambilight+hue for both iOS and Android works with Philips Ambilight TVs (2011 model or newer, type number 6 or higher in xxPFLxxx6) to match the mood in your living room to the scenes on TV, creating a more immersive experience. Ambify for iOS and hue Disco for Android make Hue react to music, providing you with an instant dance floor.
  • Plug and play
    Philips Hue Bloom is designed to create indirect ambient lighting and is a perfect way to highlight specific furniture or architectural features in your home. And because it is a plug-based product, you can easily move it around and place it where a power socket is available. Put it on your TV cabinet, your desk or just below your favorite painting. Place it either in or out of sight, and the award-winning design will blend seamlessly with your interior.
  • Highlight with color
    Choose from 16 million colors. Add accents to your home, light a space with a splash of color or wash your walls with stunning shades. Dim down the intensity and blend soft color tones for smooth light effects.
  • Sync with music and films
    Extend your TV viewing experience to the whole room or sync light to your favorite music and see how light reacts to the rhythm. Download the third-party apps and discover the amazing things you can do with Philips Hue.
  • Smart control, home and away
    With the Philips Hue iOS and Android apps, you can control your lights remotely wherever you are. Check if you have forgotten to switch your lights off before you left home, and switch them on if you are working late.
  • Timers for your convenience
    Philips Hue can make it seem like you're at home when you're not, using the schedule function in the Philips Hue app. Set the lights to come on at a pre-set time, so the lights are on when you arrive home. You can even set rooms to light up at different times. And of course, you can let the lights turn off gradually in the night, so you never have to worry whether you've left any lights on.
  • Installation-free dimming
    Experience guaranteed smooth dimming with Philips Hue. Not too bright. Not too dark. Just right. No need for wires, an electrician or installation.
  • Control it your way
    Connect your Philips Hue lights with the bridge and start discovering the endless possibilities. Control your lights from your smartphone or tablet via the Philips Hue app, or add switches to your system to activate your lights. Set timers, notifications, alarms and more for the full Philips Hue experience. Philips Hue even works with Amazon Alexa, Apple Homekit and Google Home to allow you to control your lights with your voice.
Philips Hue Iris - decoration lamp - LED - 10 W - clear
Decoration lamp
Light Source Type
LED
Dimmer
Clear
Wattage
10 W
Luminous Power
210 lumens
Beam Angle
120 degree(s)
AC 100 - 240 V
Decoration lamp
Dimmer
Double insulated, Android compatible, iOS compatible, auto power on/off, power off timer, ZigBee Light Link, diffused light effect
Light Source
LED
Built-in LED Lamp
Wattage
10 W
Luminous Power
210 lumens
Beam Angle
120 degree(s)
Lifetime
20000 hours
Colour changing LED
Power Requirements
AC 100 - 240 V
Product Material
Synthetics
Body Colour
Clear
Power adapter (UK)
IP20
Warranty
2 years
188 mm
185 mm
20 mm
874 g
