Philips Hue Intelligent Motion Sensor
Quicklinx: CJ05WS00 Mfr#: 929001260701
Automatic motion detection
Connect the Philips Hue motion sensor to your Philips Hue bridge via the Philips Hue app, and it will automatically turn on your Philips Hue lights when you enter a room. Perfect for your hallway, bathroom, basement or garage. You can choose in the app which scene or light setting should be triggered when motion is detected. The lights will turn off automatically, when there is no longer motion detected.
Day and night setting
It's possible to set different light settings for day and night. During the day, the sensor can trigger crisp white light to help you see better. At night, it can turn on a gentle night light when you, your partner or child gets out of bed. Just enough to help you navigate in the dark, without waking up the rest of the family.
What's in the box?
  • 1x Philips Hue Motion Sensor
Philips Hue - ambient light sensor / motion sensor - ZigBee Light Link
Ambient light sensor / motion sensor
Sensor Type
Ambient light, motion
Functions
Light control, motion detection
Power Source
Wireless - ZigBee Light Link
5.5 cm x 2 cm x 5.5 cm
Sensor Type
Functions
Power Source
Motion Sensor
Detection Mode
Passive infrared (PIR)
Detection Range
5 m
Detection Angle
100 degree(s)
AAA type
Required Qty
2
Warranty
IP42
5.5 cm
2 cm
5.5 cm
