Show your guests how much you care with this affordable professional TV. You will enjoy dedicated hospitality features like a branded welcome page, installation via USB and menu and control locking.
4k Ultra HD resolution
See TV like never before thanks to four times the resolution of a conventional Full HD TV. 3840 x 2160 pixels provide an image so refined, so lifelike, it's a window to a great world. -
Welcome page
A welcome page is displayed each time the TV set is switched on. The welcome page can be branded and customized easily at the time of installation via a simple welcome image in .png format. -
USB cloning
Provides the ability to easily copy all programming and channel programming settings from one TV into other TV sets in less than a minute. The feature ensures uniformity between TV sets and significantly reduces installation time and costs. -
USB - photos, music, video
Share the fun. Connect your USB memory stick, digital camera, mp3 player or other multimedia device to the USB port on your TV to enjoy photos, videos and music with the easy to use onscreen content browser. -
One combined channel list
One integrated channel list for digital and analog channels. This allows the guest to zap seamless between analog and digital channels. -
Advanced volume control
With advanced volume control you can install the start-up volume of the TV and predefine the volume range with which the TV set is allowed to operate, preventing excessive volume adjustments and avoiding disturbance of next door guests. -
Local control locking
By disabling or enabling the local control locking, the administrator can prevent unauthorized use of the TV via the control buttons, saving the hotelier overheads. -
Installation menu locking
Prevents unauthorized access to installation and configuration settings, to ensure maximum guest convenience and avoid unnecessary reinstalling costs. -
Low power consumption
Philips TVs are designed to minimize power consumption. This will not only reduce environmental impact but also lower operating costs.
- Philips 65HFL2879T Professional Studio - 65" LED-backlit LCD TV - 4K - for hotel / hospitality
- Product Type
- LED-backlit LCD TV
- Diagonal Class
- 65"
- Commercial Use
- Yes - hotel / hospitality
- Black
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- Composite, HDMI, SCART
- HDMI Ports Qty
- 2 ports
- PC Interface
- VGA (HD-15)
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-T, DVB-T2
- Analogue TV Tuner
- PAL, SECAM
- Commercial Features
- Screen welcome message, prison mode, Multi remote control, Wake Up Alarm
- Settings Cloning Capability
- Speaker System
- 2 speakers
- Sound Effects
- Incredible Surround
- USB
- Included Accessories
- Remote control, 2 AAA batteries
- Voltage
- AC 230V (50/60 Hz)
- Energy Class
- Class A++
- Power Consumption (On mode)
- 82 W
- Power Consumption Stand by
- 0.3 Watt
- Energy Consumption per Year
- 119 kWh
- Dimensions (WxDxH) - without stand
- 145.9 cm x 7.35 cm x 84.1 cm
- 23.5 kg
- Product Type
- Energy Class
- Class A++
- 82 W
- 119 kWh
- Diagonal Class
- 65"
- Commercial Use
- Series
- Professional Studio
- TV Tuner
- TV Tuner Presence
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- VGA (HD-15)
- Modes
- Eco mode
- Dimensions
- Without stand
- 145.9 cm
- 7.35 cm
- 84.1 cm
- 23.5 kg
- Enclosure Colour
- Black
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Image Contrast Ratio
- 4000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- One touch Play, security lock slot (cable lock sold separately), USB Cloning, sleep timer
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 400 x 400 mm
TV Tuner
- Analogue TV Tuner
- PAL, SECAM
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
- Digital TV Service
- MHEG
Video Features
- Analogue Video Input Signals
- PAL, SECAM
- Teletext
- Electronic Programme Guide
- Digital EPG, Now & Next
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, MPEG-4, AVI, MKV, TS, AVC, H.264, HEVC
- Supported Audio Formats
- MP3, WMA, WAV, AAC
- Supported Pictures Formats
- BMP, JPG, PNG
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
- Remote Control Pass Through
Audio System
- Surround Mode
- Sound Effects
- Equaliser
- Speaker System
- 2 speakers
- Output Power / Total
- 16 Watt
- Balance control, Down-firing Speaker, Auto Volume Leveller (AVL), Audio Return Channel (ARC), Dynamic Bass Sound
- Speakers
- 2 x speaker - 8 Watt
Network & Internet Multimedia
- Supported Consumer Electronics Control (CEC)
- EasyLink
- Connector Type
- Composite video/audio input - side , USB 2.0 - side , 2 x HDMI - rear , SCART (RGB / Composite) - rear , VGA input - rear , Digital audio output (optical) - rear , Headphones - side
- 2 AAA batteries
- Power Device
- Power supply
- Input Voltage
- 0.3 Watt
- On/off timer, system standby
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 145.9 cm x 7.35 cm x 84.1 cm x 23.5 kg , Panel with stand - 145.9 cm x 34.5 cm x 90.2 cm x 24.1 kg
- 5 °C
- 45 °C
