Philips 55BDL3010Q 55" 3840x2160 8ms VGA DVI HDMI LED Large Format Display
Quicklinx: FFBCWS00 Mfr#: 55BDL3010Q/00
Inform and enthral with a Philips Q-Line Professional 4K Ultra HD Display. This reliable solution can be up and running as quickly as you need - with no additional hardware.
  • CMND system management
    Take control of your Philips Professional Display network. CMND lets you manage, update, maintain and play via one easy-to-use interface. From installation to daily operation.
  • CMND and Control
    Run your display network over a local (LAN) connection. CMND and Control allows you to perform vital functions like controlling inputs and monitoring display status. Whether you're in charge of one screen or 100.
  • Integrated media player
    Easily schedule content to play from USB, internal memory, local network or via the Internet. Your Philips Professional Display will wake from standby to play the content you want, and then return to standby once playback has finished.
  • FailOver
    From waiting room to meeting room, never show a blank screen. FailOver lets your Philips Professional Display switch automatically between primary and secondary inputs - ensuring that content keeps playing even if the primary source goes down. Simply set a list of alternate inputs to be sure your business is always on.
Philips 55BDL3010Q Q-Line - 55" Class (54.6" viewable) LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/395507
Diagonal Class
55"
Diagonal Size
54.6"
Commercial Use
Yes - digital signage
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/60p, 480/60i, 3840/30p, 3840/60p
Max Number of Screens
225
Video Interface
HDMI
HDMI Ports Qty
4 ports
LAN
PC Interface
DVI
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
CMND management
Picture Enhancements
Pixel Shift
Speaker System
2 speakers
USB
Remote control, batteries
Voltage
AC 120/230 V
Energy Class
Class G
125 Watt
Power Consumption (On mode)
125 W
Power Consumption Stand by
0.5 Watt
123.92 cm x 6.171 cm x 71.16 cm
15.82 kg
3-year warranty
Energy Class
Class G
125 Watt
125 W
125 kWh/1000h
Diagonal Class
55"
Diagonal Size
54.6"
Commercial Use
Series
Q-Line
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
4 ports
PC Interface
DVI
Pixel Shift
Dimensions
Without stand
123.92 cm
6.171 cm
71.16 cm
15.82 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
Direct-lit LED
Dynamic Contrast Ratio
500000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Display Menu Language
Multilingual
Backlight Life
50,000 hour(s)
Commercial Features
CMND management
Operation Hours / Days
18 / 7
Video Wall
225
Stands & Mounts
Flat Panel Mount Interface
200 x 200 mm, 400 x 400 mm
VESA Compatibility
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 720 x 400, 1920 x 1080, 1440 x 900, 1280 x 800
Media Player
Supported Video Formats
MPEG-4, WMV, ASF, AVI, MKV, MOV, VOB, FLV, TS, 3GPP, DAT, TP, TRP, MPG, MPEG, 3GP
Supported Audio Formats
MP3, WAV, AAC, ASF, MP4
Supported Pictures Formats
BMP, PNG, JPEG
USB Port
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
DVI-D input , 4 x HDMI , USB , Audio line-in , Audio line-out , Serial input , Serial output , Infrared input , Infrared output , LAN
Batteries
Serial cable , IR extender cable - 1.8 m
FCC Class B certified, BSMI, CB
Power supply
Input Voltage
AC 120/230 V
0.5 Watt
WOL (Wake on LAN), smart power
Limited warranty - 3 years
20 - 80%
