Philips 40HFL3011T 40" EasySuite LED Commercial TV
Quicklinx: FF9HWS00 Mfr#: 40HFL3011T/12
  • 1080p
  • DVB-T
Send the right message to your guests with superb picture quality and the ability to show branded, interactive hotel pages.
  • CMND & Control: effortless maintenance of your TV's
    CMND & Control allows for remote configuration and installation of your TV's from a central location, without having to visit any rooms. Update and manage all your displays, with minimal effort, all without having to disturb your guests.
  • CMND & Create: show the information you want, when you want
    CMND & Create allows you to provide the information you want, when you want. The content management module of CMND, it allows for easy creation and distribution of interactive, branded hotel web pages. Tailor your TV's to give guests the most up to date information with the latest developments in your hotel, all in real time.
  • MyChoice compatibility for recurring revenues
    MyChoice offers a simple and low-cost way to offer your guests premium TV channels. At the same time it delivers an additional revenue stream which allows you to recover your initial TV investment.
  • Greet your guests with a customizable welcome page
    A welcome page is displayed each time the TV set is switched on. The welcome page can be branded and customized easily at the time of installation via a simple welcome image in .png format.
  • On-screen clock display for optimal guest convenience
    With the on-screen clock display, guests can easily access the current time. At a push of a button the clock is being displayed on the TV screen combining enhanced visibility and lower power consumption.
  • SmartInfo for branded, interactive hotel info pages
    SmartInfo allows you to provide hotel or city information to your guests through SmartUI. Your guests have access to this interactive hotel webpage even when the TV is not connected to your intranet or internet. You can change the information regularly and easily to keep your guests up to date with all the latest developments in your hotel.
  • Installation menu locking
    Prevents unauthorized access to installation and configuration settings, to ensure maximum guest convenience and avoid unnecessary reinstalling costs.
  • Nurse-call compatibility optimized for the Healthcare sector
    Nurse-call system compatibility makes Philips Healthcare TVs a highly integrated tool that provides not only entertainment options for the user/patient but also gives convenient access to help in medical emergencies.
  • Additional headphone connection for personal listening
    This speaker system features additional headphone connection. Connect your own headphone for a more personal listening experience whenever you want it.
Philips 40HFL3011T EasySuite - 40" LED-backlit LCD TV - Full HD - for hotel / hospitality
LED-backlit LCD TV
Diagonal Class
40"
Commercial Use
Yes - hotel / hospitality
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
1080/60p
Frame Rate & Enhancement Technology
200 Hz Perfect Motion Rate
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-T, DVB-T2
Analogue TV Tuner
PAL
Internet Streaming Services
HbbTV
Commercial Features
Screen welcome message, prison mode, VSecure, healthcare mode, mychoice, Serial Xpress Protocol, Bathroom Speaker Output, Double isolation Class II, Independent main speaker mute, HTML5 support, SmartInfo, Nurse call system compatible, Multi remote control, CMND management, Wake Up Alarm
Settings Cloning Capability
Speaker System
2 speakers
Sound Effects
Incredible Surround
USB
2 ports
Philips 22AV1503A/12 remote control, 2 AAA batteries
Voltage
AC 230V (50/60 Hz)
Energy Class
Class A+
Power Consumption (On mode)
46 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
68 kWh
91.8 cm x 7.7 cm x 53.2 cm
7.6 kg
LED-backlit LCD TV
Energy Class
Class A+
46 W
68 kWh
Diagonal Class
40"
Commercial Use
Series
EasySuite
TV Tuner Presence
Video Interface
HDMI Ports Qty
3 ports
Modes
Eco mode, hotel mode
Design
Flame retardant cabinet
Protection
Theft protection
Dimensions
Without stand
91.8 cm
7.7 cm
53.2 cm
7.6 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Brightness
280 cd/m²
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Commercial Features
Pixel Plus HD, Slide Show Function, One touch Play, security lock slot (cable lock sold separately), Scheduler
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
200 x 200 mm
TV Tuner
Analogue TV Tuner
PAL
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Digital TV Service
MHEG
Video Features
Analogue Video Input Signals
NTSC, PAL, SECAM
Input Video Formats
1080/60p
Teletext
Electronic Programme Guide
Digital EPG, Now & Next
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, WMV, AVI, MKV, TS, AVC, H.264, VC-1, HEVC, MPG
Supported Audio Formats
MP3, WMA, WAV, AAC
Supported Pictures Formats
BMP, JPG, GIF, PNG
USB Port
USB Ports Qty
2
Remote Control
Remote control
Remote Control Model
Joystick, low battery alert, battery anti-theft protection
Audio System
Digital Audio Format
Dolby Digital output
Surround Mode
Sound Effects
Incredible Surround
Speaker System
2 speakers
Output Power / Total
16 Watt
Down-firing Speaker, Auto Volume Leveller (AVL), Audio Return Channel (ARC)
Speakers
2 x main channel speaker - 8 Watt
Network & Internet Multimedia
Functionality
WEB browsing
HbbTV
Supported Consumer Electronics Control (CEC)
EasyLink
Connector Type
2 x HDMI - rear , USB 2.0 - rear , Digital audio output (optical) - rear , Audio line-in - rear , Composite video / component video input - rear , Audio line-in , Remote control - rear , Speakers output - rear , HDMI - side , USB 3.0 - side , Headphones
2 AAA batteries
Power supply
Input Voltage
AC 230V (50/60 Hz)
0.3 Watt
System standby
Dimensions & Weight Details
Panel without stand - 91.8 cm x 7.7 cm x 53.2 cm x 7.6 kg , Panel with stand - 91.8 cm x 22.2 cm x 59.7 cm x 9.5 kg
