Peerless-AV Video Wall Ceiling Mount for 2x2 Configs for 40-55" Displays
Quicklinx: 9Z0DWS00 Mfr#: DS-VWT955-2X2
£1,881.64 ex VAT
£2,257.96 inc VAT
Video wall displays no longer need to be limited to just walls and carts. With the Peerless-AV DS-VWT955-2X2, a video wall display can now be mounted to a ceiling. The tool-less micro adjustable design provides placement of four displays in a 2 x 2 configuration, neatly aligned on the same plane. The tilting adjustment options of 5, 10, 15 and 20 degrees means you can be assured of the perfect viewing angle for your application. It is ideal for department stores, entertainment venues or other large public areas. Compatible with Peerless-AV fixed length and adjustable length columns.
  • Versatile adjustments
    With both tilt and adjustable height and width features, this mounting kit offers a flexible solution to meet various digital signage needs, ensuring optimal viewing angles and display configurations.
  • Comprehensive compatibility
    Designed to support a wide range of display sizes from 40" to 50" and equipped with a flat panel mount interface of 200 x 200 mm and 600 x 400 mm, this ceiling mount is versatile enough to accommodate most digital signage displays.
Peerless Digital Signage Video Ceiling Mount DS-VWT955-2X2 mounting kit - black
Mounting kit - ceiling mountable
Mounting Components
Ceiling mount
Adjustments
Tilt
Recommended Display Size
40"-50"
VESA Mounting Interface
200 x 200 mm, 600 x 400 mm
AV Furniture
Mounting kit
Mounting Components
Ceiling mount
Placing / Mounting
Ceiling mountable
40"-50"
Adjustments
Tilt
Adjustable height, adjustable width
Brand: Peerless-AV
Price Range Ex VAT: £1500+
