Peerless-AV Tru Vue TRVT561 Mobile Height Adjustable Trolley 32"-60"
Sleek and tidy mobile AV solution
Quicklinx: 9X9CWS00 Mfr#: TRVT561
37 in stock
£198.82 ex VAT
£238.58 inc VAT
The TruVue TRVT561 provides a sleek and tidy mobile solution for 32"-60" displays. Complete with 2 heavy duty poles to display the screen at a maximum height of 1500 mm (59").
Its unique and convenient TV height adjustment is complimented by spring plunges providing 90-degree adjustments for landscape and portrait viewing, cable management, and 4 heavy duty braked caster wheels. The TRVT560 also comes with a spacious metal shelf for AV components.
  • Height Adjustable Max: 1530mm (60.2")
  • Universal VESA┬« 200x200 up to 600x400mm
  • Plastic component shelf for AV equipment
  • Internal Cable Management; hide cables to provide a tidy look.
  • Smooth matt black finish
  • Includes height adjustable VC Shelf
Height Adjustment
Adjusts & Locks Position
Creates a clean, professional installation while protecting and organising the cables
x4 Locking Caster Wheels
Provides stabilty
Peerless Tru Vue TRVT560 - cart
Cart
84.1 cm x 72 cm x 117.9 cm
Adjustments
Tilt
30 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
32"-60"
VESA Mounting Interface
200 x 200 mm, up to 800 x 500 mm
Max Load Weight
45.5 kg
Powder coat, smooth matte black
Wheels Qty
4
5-year warranty
84.1 cm
72 cm
117.9 cm
30 kg
AV Furniture
Cart
Recommended Use
LCD / plasma panel
Cable Management
Integrated cable management
32"-60"
Adjustments
Tilt
Max Load Weight
45.5 kg
Wheels Qty
4
Adjustable height, locking casters, portrait to landscape movement, metal shelf
Limited warranty - 5 years
Resources
The following resources are available for the Peerless-AV Tru Vue TRVT561 Mobile Height Adjustable Trolley 32"-60"
Brand: Peerless-AV
Price Range Ex VAT: 150 - 300
