Ultra Slim is the world's thinnest tilting mounting solution at less that 1.7cm - yes that's only 17mm! - making it almost invisible once installed. Designed for the next generation of super slim LCD & LED panels this product is a step ahead of anything else available in the market. Own the most discrete wall mount ever developed with the Ultra Slim range from Peerless.
- Peerless Slimline Universal Ultra-thin Tilt Wall Mount SUT660P - mounting kit - for flat panel - gloss black
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Wall mount
- 93.3 cm x 1.7 cm x 43.8 cm
- Adjustments
- Tilt
- 5.2 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 37"-60"
- VESA Mounting Interface
- 800 x 400 mm
- Max Load Weight
- 45 kg
- Material
- Cold-rolled steel
- Gloss black
- 93.3 cm
- 1.7 cm
- 43.8 cm
- 5.2 kg
- Material
- Cold-rolled steel
- Gloss black
AV Furniture
- Mounting kit
- Wall mount
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 800 x 400 mm
- 37"-60"
- Adjustments
- Tilt
- Max Load Weight
- 45 kg
- Adjustable depth, scratch-resistant, horizontal shift
