Peerless-AV Peerless Locking Flat Wall Mount For 32-58" LCD & Plasma Screens, Ve
Quicklinx: 7MXQWS00 Mfr#: PFL650
£156.20 ex VAT
£187.44 inc VAT
Peerless' Security Lockable Mounts offer the next level of security within the wall mount range with a secure locking bar and provided padlock.
  • Versatile display compatibility
    Designed to support flat panels ranging from 37" to 75", the Peerless PFL650 mounting kit ensures a perfect fit for a wide array of display sizes, making it an ideal choice for both home and commercial settings.
  • Enhanced security features
    With its lockable design and a locking bar included, the Peerless PFL650 mounting kit offers an added layer of security, ensuring that your flat panel remains safe and securely mounted at all times.
  • Easy adjustment
    Featuring a landscape function and lateral shift accessory, this mounting kit allows for effortless adjustment and positioning of your flat panel, ensuring optimal viewing angles and a tailored entertainment or presentation experience.
Peerless PFL650 mounting kit - for flat panel - black
Mounting kit
Mounting Components
Lateral shift accessory, locking bar
78.1 cm x 4.3 cm x 42 cm
Recommended Use
Flat panel
Recommended Display Size
37"-75"
VESA Mounting Interface
700 x 400 mm
Max Load Weight
79 kg
78.1 cm
4.3 cm
42 cm
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
700 x 400 mm
37"-75"
Max Load Weight
79 kg
Landscape function, lockable
Brand: Peerless-AV
