Peerless-AV Ultra-Slim Universal Articulating Wall Arm for 42" to 90" Ul
Quicklinx: BY0GWS00 Mfr#: SUA771PU
£363.75 ex VAT
£436.50 inc VAT
The Peerless-AV universal ultra-slim articulating wall mount is designed exclusively for ultra-thin displays. Featuring a dual-arm construction, the SUA771PU is robust enough to hold larger displays firmly in any position - landscape or portrait - while still offering an ultra-low profile. An advanced I-shaped adapter plate makes it easy to access the back of the display, keeping hardware hidden, and features internal cable management, providing a clean, professional look that transitions smoothly from the wall to the display. With a gloss finish, the SUA771PU matches any decor. Full-motion capabilities allow you to swivel, tilt, extend or retract your display for the perfect viewing angle.
  • Post-installation height adjustment
    Vertical adjustment allows to fine-tune positioning of display after installation.
  • One-touch tilt
    Provides +15/-5 degrees of vertical tilt movement for the ideal viewing angle.
  • Flexible mounting locations
    Mounts to wood stud, concrete, cinder or breeze block.
  • Ultra-low profile design
    Creates an aesthetically appealing look.
  • Adapter plate design
    Helps avoid blocking connections on back of display.
  • Integrated cable management
    Protects, contains and conceals cables for a clean, professional installation.
Peerless-AV Designer Series SUA771PU mounting kit - for flat panel - gloss black
Mounting kit - wall-mountable
Mounting Components
Articulating wall mount
81.9 cm 44.2 cm
Adjustable Depth
4.7-63.1 cm
Tilt
-5° to 15°
Rotation
-90° to 90°
Adjustments
Roll, levelling, tilt
10.45 kg
Recommended Use
Flat panel
Recommended Display Size
42"-90"
VESA Mounting Interface
200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 800 x 400 mm, 600 x 400 mm, 300 x 200 mm, 200 x 100 mm, 300 x 300 mm
Max Load Weight
57 kg
Material
Fused epoxy
Gloss black
Package Content
Mounting hardware
5-year warranty
81.9 cm
44.2 cm
Adjustable Depth
4.7-63.1 cm
10.45 kg
Material
Fused epoxy
Gloss black
Package Content
Mounting hardware
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
Cable Management
42"-90"
Tilt
-5° to 15°
Rotation
-90° to 90°
Adjustments
Max Load Weight
57 kg
Limited warranty - 5 years
Brand: Peerless-AV
