This sleek, compact tilting wall mount delivers a big impact for mid-sized screens. Its simple hook-on installation combined with its adjustable tilt allows LCD screens to be installed and adjusted quickly. The tilt angle can be adjusted without the use of tools to give an enhanced viewing position.
Effortless installation
The integrated spirit level in the Peerless Tru Vue TRT632 mounting kit ensures a perfectly level installation, making it easier than ever to set up your flat panel display securely on the wall. -
Versatile compatibility
With flat panel mount interfaces of 100 x 100 mm, 200 x 100 mm, 200 x 200 mm, and 75 x 75 mm, this mounting kit is designed to accommodate a wide range of display sizes from 22"-40", offering a flexible solution for various flat panel models. -
Robust design
Capable of supporting flat panels weighing up to 25 kg, the Peerless Tru Vue TRT632 mounting kit combines durability with reliability, ensuring your display remains securely mounted.
- Peerless Tru Vue TRT632 mounting kit - for flat panel - black powder coat
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Tilt wall mount
- 22.6 cm x 4 cm x 22 cm
- Recommended Use
- Flat panel
- Recommended Display Size
- 22"-40"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
- Max Load Weight
- 25 kg
- Black powder coat
- 5-year warranty
- 22.6 cm
- 4 cm
- 22 cm
- Black powder coat
AV Furniture
- Mounting kit
- Tilt wall mount
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 22"-40"
- Max Load Weight
- 25 kg
- Integrated spirit level
- Limited warranty - 5 years
