The TruVue™ series wall mounts combine ease of installation with viewing flexibility. With TRF650, a low-profile design positions the TV just 30mm (1.18") from the wall. The Hook-and-Hang™ system offers easy, one-person installation of the TV. The adaptors hook onto the wall plate for a quick, simple and secure installation.
- Low profile design positions the TV just 30mm (1.18") from the wall.
- Universal mount fits TVs with mounting patterns up to VESA 700x400mm.
- Simple Hook-and-Hang™ design for quick and easy installation.
- Mounts to wood studs, concrete, cinder block or metal studs (metal stud accessory required).
- Installation hardware included.
- Tested to four times stated load capacity.
Effortless installation
The integrated spirit level ensures a perfectly level installation, making the setup process quick and hassle-free for a flawless viewing experience. -
Versatile compatibility
Designed to support flat panels ranging from 37" to 75", this mounting kit accommodates a wide variety of screen sizes, ensuring a perfect fit for your display. -
Robust design
With a maximum load weight of 70 kg and compatibility with mounting patterns up to 700 mm by 400 mm, this mount provides a secure and stable foundation for your flat panel.
- Peerless Tru Vue TRF650 mounting kit - for flat panel - black powder coat
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Wall mount
- 72.6 cm x 3 cm x 43 cm
- Recommended Use
- Flat panel
- Recommended Display Size
- 37"-75"
- Max Mounting Pattern Size
- 700 x 400 mm
- Max Load Weight
- 70 kg
- Black powder coat
- 5-year warranty
- 72.6 cm
- 3 cm
- 43 cm
- Black powder coat
AV Furniture
- Mounting kit
- Wall mount
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 700 x 400 mm
- 37"-75"
- Max Load Weight
- 70 kg
- Integrated spirit level
- Limited warranty - 5 years
