Peerless-AV Trolley For 32-75" Flat Panel Displays - Tinted Glass Shelf
Quicklinx: 9Z3MWS00 Mfr#: SR560G
The new SmartMount line of Flat Panel TV Carts offers the most complete mobile solutions for any application. These versatile presentation carts allow you to hold meetings with A/V support or simply to display information. The full line of accessories enables each cart to be fully tailored to meet your specific requirements. Whether video conferencing from a boardroom or presenting on a trade show floor, Peerless' Flat Panel TV Carts are the solutions you need.
  • Robust construction
    Crafted from cold-rolled steel and complemented by a tinted glass shelf, this TV cart offers a durable and stylish solution for displaying flat panels.
  • Versatile display compatibility
    Designed to support flat panel displays ranging from 32" to 75", or 81.3 to 152.4 cm, ensuring a perfect fit for a wide range of screen sizes.
  • Optimized viewing
    Featuring a flat panel mount interface of 600 x 400 mm, this cart allows for a secure and optimized viewing experience.
  • Convenient storage
    Equipped with a single shelf, this cart provides ample space for AV components or personal items, keeping them organized and easily accessible.
Peerless SmartMount Universal Flat Panel TV Cart SR560G - cart
Cart
90.4 cm x 70.6 cm x 170 cm
33.6 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
32" - 75"
Max Load Weight
90.6 kg
Material
Cold-rolled steel, tinted glass
5 years warranty
90.4 cm
70.6 cm
170 cm
33.6 kg
Material
AV Furniture
Cart
Recommended Use
LCD / plasma panel
Shelf Qty
1
32" - 60"
Max Load Weight
90.6 kg
5 years warranty
Service & Support Details
Limited warranty - 5 years
