Product
Peerless-AV Tilting Wall Mount for Panasonic 85" Displays
Quicklinx: 9Z15WS00 Mfr#: PANA-85WM
£441.70 ex VAT
£530.04 inc VAT
Peerless' PANA-85WM wall mount is specifically designed to accommodate this extra-large Panasonic plasma display. Its hook-on design allows for easy hanging of the extra large screen on the mounts wall plate. Its triple stud wall plate secures the mount to wood studs, concrete or cinder block. To assure the display is seen in all its beauty, the PANA-85WM wall mount tilts the screen from 0 to 3.5 to 7 degrees so the life-size display is set to an optimal viewing angle.
Peerless Custom Wall Mount PANA-85WM - wall mount
Wall mount
101 cm x 19.6 cm x 145 cm
45 kg
Recommended Use
Plasma panel
Recommended Display Size
85"
Max Load Weight
122 kg
Matte black
5 years warranty
101 cm
19.6 cm
145 cm
45 kg
Matte black
AV Furniture
Wall mount
Mounting Components
Wall plate, tilt wall mount
Recommended Use
Plasma panel
85"
Max Load Weight
122 kg
Landscape function, portrait function
Limited warranty - 5 years
Brand: Peerless-AV
Price Range Ex VAT: 300 - 500
