Peerless-AV Tilt Box for up to 75" Displays
Quicklinx: 9Z1RWS00 Mfr#: PLCM-2/BK
This base mount is designed only for up to 71" screens. It requires appropriate extension column, screen-specific adapter and ceiling plate for various ceilings, all sold separately.
Peerless Solid-Point Flat Panel Straight Column Mount PLCM 2 mounting kit - for flat panel - black
Mounting kit - ceiling mountable
Mounting Components
Tilt bracket, ceiling arm box, retaining collar
Adjustments
Tilt
3.4 kg
Recommended Use
Flat panel
Recommended Display Size
32" - 71"
Max Load Weight
102.1 kg
Material
Cold-rolled steel
5-year warranty
3.4 kg
Material
Cold-rolled steel
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
Placing / Mounting
Ceiling mountable
32" - 71"
Adjustments
Tilt
Max Load Weight
102.1 kg
Penta-pin security screws
Limited warranty - replacement - 5 years
