The Flat Panel Stand is designed to provide ideal display viewing position, centralize audio video components and match the decor of any environment. The full line of accessories enables each stand to be fully tailored to meet specific requirements; whether video conferencing from a boardroom or presenting on a trade show floor. And the internal cable management hides all the AV cabling, providing a clean, clutter-free look.
Incremental tilt
Incremental tilt makes it simple to set multiple angles for preferred viewing and aids in reducing screen glare. -
Vertical adjustment
Continuous vertical adjustment is designed for perfect viewing height. -
Component placement
Metal or tinted tempered glass shelf provides storage space for A/V components. These shelves are designed to ensure equipment and user safety.
- Peerless Flat Panel Stand SS560M stand - for flat panel / AV system - black
- Product Type
- Stand
- 90.4 cm x 68.3 cm x 160 cm
- Adjustments
- Tilt
- 33.6 kg
- Recommended Use
- Flat panel / AV system
- Recommended Display Size
- 32"-65"
- Max Load Weight
- 68 kg
- Material
- Metal, glass, steel
- Black
- 5-year warranty
- 90.4 cm
- 68.3 cm
- 160 cm
- 33.6 kg
- Material
- Black
AV Furniture
- Stand
- Recommended Use
- Shelf Qty
- 1
- Cable Management
- Integrated cable management
- 32"-65"
- Adjustments
- Tilt
- Max Load Weight
- 68 kg
- Adjustable height
- Limited warranty - 5 years
