Peerless-AV Modular Series Projector Mount Adaptor
Quicklinx: 7HN5WS00 Mfr#: MOD-APRG
The Peerless Modular Series has been introduced as a mounting system with just over a dozen components that combine to meet virtually any installation application.
  • Versatile mounting
    Designed specifically for projectors, the Peerless Modular Series Projector Mount Adaptor offers a secure and versatile mounting solution. This component ensures your projector is perfectly positioned for optimal viewing angles and image clarity.
  • Seamless integration
    The sleek design of the Peerless Modular Series Projector Mount Adaptor seamlessly integrates with any decor. Its compatibility with a wide range of projectors makes it an ideal choice for both home and professional settings.
Peerless Modular Series Projector Mount Adaptor mounting component - for projector - black
Mounting component
Mounting Components
Mounting adapter
7.8 cm x 13.2 cm x 2.4 cm
Recommended Use
Projector
Max Load Weight
30 kg
7.8 cm
13.2 cm
2.4 cm
AV Furniture
Mounting component
Mounting Components
Mounting adapter
Recommended Use
Projector
Max Load Weight
30 kg
