FPZ-670 is the only stand on the market that is designed to support up to two 50" to 71" screens back-to-back. It is one of the sharpest looking, most robust and functional stands ever. It is complemented by its sturdy base that provides plenty of concealed room for content drivers and surge protectors. Its internal cable management system conceals cables and cords, delivering a clean look for any application.
Versatile display compatibility
The Peerless Flat Panel Stand is designed to support a wide range of display sizes, from 50" to 71", accommodating both standard and large format screens for a flexible viewing experience. -
Flexible viewing options
With features that allow for adjustable height and portrait to landscape movement, this stand offers flexibility, ensuring the perfect viewing angle in any setting. -
Robust support
Engineered to hold up to 181 kg, this stand provides a secure and stable foundation for 2 LCD displays, making it an ideal choice for commercial and educational environments alike.
- Peerless Flat Panel Stand FPZ-670 stand - for 2 LCD displays - black
- Product Type
- Stand
- 101 cm x 122 cm x 184 cm
- 88.1 kg
- Recommended Use
- 2 LCD displays
- Recommended Display Size
- 50" - 71"
- VESA Mounting Interface
- 100 x 100 mm, 200 x 200 mm, 200 x 100 mm
- Max Load Weight
- 181 kg
- Black
- 5-year warranty
- 101 cm
- 122 cm
- 184 cm
- 88.1 kg
- Black
AV Furniture
- Stand
- Recommended Use
- 2 LCD displays
- 50" - 71"
- Max Load Weight
- 181 kg
- Adjustable height, portrait to landscape movement
- Limited warranty - 5 years
