Peerless-AV Flat Panel Display Stand For 50-71" Displays
Quicklinx: 9Z3PWS00 Mfr#: FPZ-670/BK
FPZ-670 is the only stand on the market that is designed to support up to two 50" to 71" screens back-to-back. It is one of the sharpest looking, most robust and functional stands ever. It is complemented by its sturdy base that provides plenty of concealed room for content drivers and surge protectors. Its internal cable management system conceals cables and cords, delivering a clean look for any application.
  • Versatile display compatibility
    The Peerless Flat Panel Stand is designed to support a wide range of display sizes, from 50" to 71", accommodating both standard and large format screens for a flexible viewing experience.
  • Flexible viewing options
    With features that allow for adjustable height and portrait to landscape movement, this stand offers flexibility, ensuring the perfect viewing angle in any setting.
  • Robust support
    Engineered to hold up to 181 kg, this stand provides a secure and stable foundation for 2 LCD displays, making it an ideal choice for commercial and educational environments alike.
Peerless Flat Panel Stand FPZ-670 stand - for 2 LCD displays - black
Stand
101 cm x 122 cm x 184 cm
88.1 kg
Recommended Use
2 LCD displays
Recommended Display Size
50" - 71"
VESA Mounting Interface
100 x 100 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
181 kg
5-year warranty
101 cm
122 cm
184 cm
88.1 kg
AV Furniture
Stand
Recommended Use
2 LCD displays
50" - 71"
Max Load Weight
181 kg
Adjustable height, portrait to landscape movement
Limited warranty - 5 years
