Peerless-AV A/V Component Shelf For FPZ-600
Quicklinx: BX23WS00 Mfr#: ACC325
AV component shelf designed to work specifically with the flat panel stand.
Peerless ACC325 shelf - for audio/video components - black
Shelf
53.3 cm x 48.3 cm x 4.4 cm
7.4 kg
Recommended Use
Audio/video components
Max Load Weight
11 kg
5-year warranty
Flat Panel Display Stand FPZ-600
53.3 cm
48.3 cm
4.4 cm
7.4 kg
AV Furniture
Shelf
Recommended Use
Max Load Weight
11 kg
Scratch-resistant
Limited warranty - 5 years
Peerless Flat Panel Display Stand FPZ-600
