Parrot Flower Power Wireless Plant Monitor - Brown
Quicklinx: BL3ZWS00 Mfr#: PF900000AB
In a pot or in the ground, the Parrot Flower Power monitors and analyzes the four parameters essential to your plant's health. Whenever your Flower Power detects that your attention is needed, you will receive notification on your smartphone or tablet which uses Bluetooth Smart to connect to Flower Power. You will know when to water them, add fertilizer, or repot your plant to ensure its well-being, and yours!
  • Your sensor assesses your plants' needs
  • The App sends alerts to your smartphone
  • You take care of your plants
Parrot Flower Power - plant sensor
Plant sensor
Environment
Indoor, outdoor
Sensor Type
Sunlight, temperature, fertiliser, moisture
Functions
Temperature measuring, fertiliser measuring, soil moisture measuring, luminosity measuring
Wireless - Bluetooth 4.0
Supported Host Device OS
iOS, Android
Brown
64 mm x 32 mm x 190 mm
Plant sensor
Sensor Type
Environment
Indoor, outdoor
Functions
iOS, Android
Push notification, 7000 plants PlantDB, indoor/outdoor usage, water-resistant
Internet of Things (IoT)
Compatible Services
IFTTT
CPU
CC2540 CC2540
Manufacturer
Texas Instruments
AAA rechargeable battery
Brown
64 mm
32 mm
190 mm
45 g
-10 °C
55 °C
