Panasonic SC-ZT1 - Wireless speaker system - 160 Watt (Total) - 2-way
Quicklinx: 75F1WS00 Mfr#: SC-ZT1E-S
Panasonic has unveiled its first fully wireless home theater system, the SC-ZT1. Now home theater enthusiasts can do away with speaker cables and arrange speakers throughout the room without worrying about tripping hazards or unsightly cables crossing the floor. Uncompressed audio data is sent over a wireless 2.4-GHz frequency band to ensure high-quality sound.
The SC-ZT1 debuts Panasonic's elegant Sound Slim Speakers which are engineered by arranging four speakers vertically inside a slim pole to achieve a parallel sound system. This creates a lifelike virtual 7.1 sound from two ultra slim pole-type speakers, which provides ideal listening conditions whether you are lying down or sitting on a sofa in front of a TV.
Even though the SC-ZT1 is a two-speaker system, Panasonic's virtual technology lets users enjoy Dolby TrueHD and DTS-HD 7.1-channel surround sound by combining it with a Panasonic Blu-ray Disc player or recorder with built-in audio codecs - so if you don't have the space to install eight speakers, you can still enjoy realistic sound.
The speakers also boast an integrated subwoofer. This long-stroke woofer, with a diameter of approximately 12cm, is built into the speaker stand and generates sounds in the low-frequency range that are typically produced by subwoofers.
System Type
Wireless Speaker System
160 Watt
Header / Product Line
Panasonic
Speaker System / Amplification Type
Active
Speaker System / Built-in Decoders
DTS decoder
Header / Manufacturer
Panasonic
Header / Model
SC-ZT1
Header / Packaged Quantity
1
Remote Control / Type
Remote control
Speaker System / Connectivity Technology
Wireless
Speaker System / Crossover Channel Qty
2-way
