Panasonic KXMB2010 Multifunction printer
Quicklinx: 70CZWS00 Mfr#: KX-MB2010E-B
The Panasonic KX-MB2000 Series of compact multi-functional printers are an excellent choice for small offices and remote home offices. They feature a 24-ppm high-speed printer, diverse copy functions, a high-resolution color scanner with up to 9600 dpi (interpolated) and a standard network connection. The compact KX-MB2000 Series body contains the functions you need for business.
Panasonic KX-MB2010 - multifunction printer - B/W
Copier Type
Digital
Printing Technology
Laser (monochrome)
Max Copying Speed
Up to 24 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 24 ppm
Max Printing Resolution
Up to 600 x 600 dpi
Scanning
600 x 1200 dpi
Original Type
Sheets
Document Feeder Capacity
20 sheets
Media Size
Legal (216 x 356 mm) (max)
Media Type
Plain paper
Standard Media Capacity
250 sheets
Connection Availability
USB 2.0, LAN
AC 230 V (50/60Hz)
42 cm x 43.2 cm x 30.5 cm
12 kg
Enclosure Colour
Copier Type
Digital
Printing Technology
Laser - monochrome
Display
2 lines x 16 characters
USB 2.0, LAN
Enclosure Colour
Standard Memory
32 MB 32 MB
Copying
Max Copying Speed
Up to 24 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Up to 600 x 600 dpi
Max Printing Speed
Up to 24 ppm
Printer Drivers / Emulations
Windows GDI driver
Scanning
Optical Resolution
600 x 1200 dpi
Interpolated Resolution
9600 x 9600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Document & Media Handling
Original Type
Sheets
20 sheets
Max Media Size
Legal
Supported Media Type
Plain paper
250 sheets
Input tray - 250 sheets - Legal (216 x 356 mm) , ADF - 20 sheets
Speed Details
Printing: up to 24 ppm , Copying: up to 24 ppm
1 x USB 2.0 , 1 x LAN
Operating System Support
MS Windows XP, MS Windows 2000, MS Windows Vista
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
900 Watt
Power Consumption Standby
11 Watt
Consumables Included
1 x toner cartridge (black) - up to 2000 pages - Panasonic KX-FAT411X , 1 x drum (black) - up to 6000 pages - Panasonic KX-FAD412X
42 cm
43.2 cm
30.5 cm
12 kg
