Panasonic KXMB2000 Multifunction printer
Quicklinx: 70CYWS00 Mfr#: KXMB2000
The Panasonic KX-MB2000 Series of compact multi-functional printers are an excellent choice for small offices and remote home offices. They feature a 24-ppm high-speed printer, diverse copy functions, a high-resolution color scanner with up to 9600 dpi. They also come bundled with the easy print utility, which includes a print image control function that simplifies the production of complex documents. The compact KX-MB2000 Series body contains the functions you need for business.
  • Data merge and print
    The easy print utility is an integrated printing tool that lets you merge and print files created using different applications, such as Microsoft Word and Excel. You can check the final image on a PC before printing, or edit the layout by rearranging pages or changing the pages to a 2-in-1, or all the way up to a 16-in-1 format. You can also add a header, footer or watermark to documents before printing. After editing the layout, you can save the image as a PDF file. These functions greatly reduce the number of trial prints and misprints.
  • Network color scanner function
    Documents can be easily scanned into a PC in color. Scanned data can also be sent in the appropriate data format directly to the bundled OCR software on a PC, to easily convert it to editable text without requiring any PC operation. Scanned data can also be saved to a Windows share folder or an FTP server, without using a PC, and then sent by e-mail.
Panasonic KX-MB2000 - multifunction printer - B/W
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser (monochrome)
Max Copying Speed
Up to 24 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 24 ppm
Max Printing Resolution
Up to 600 x 600 dpi
Scanning
600 x 1200 dpi
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Media Size
Legal (216 x 356 mm) (max)
Media Type
Plain paper
Standard Media Capacity
250 sheets
Connection Availability
USB 2.0, LAN
AC 230 V (50/60Hz)
42 cm x 43.2 cm x 25.5 cm
11 kg
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
Display
2 lines x 16 characters
USB 2.0, LAN
Standard Memory
32 MB 32 MB
Copying
Max Copying Speed
Up to 24 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Up to 600 x 600 dpi
Max Printing Speed
Up to 24 ppm
Printer Drivers / Emulations
Windows GDI driver
Scanning
Optical Resolution
600 x 1200 dpi
Interpolated Resolution
9600 x 9600 dpi
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
Max Media Size
Legal
Supported Media Type
Plain paper
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
250 sheets
Input tray - 250 sheets
Speed Details
Printing: up to 24 ppm , Copying: up to 24 ppm
1 x USB 2.0 , 1 x LAN
Operating System Support
MS Windows XP, MS Windows 2000, MS Windows Vista
AC 230 V (50/60Hz)
Power Consumption Standby
11 Watt
Warm-Up Time
16 sec
42 cm
43.2 cm
25.5 cm
11 kg
